Lower profile?
Old Jul 25, 2009 | 07:12 PM
souchak2112's Avatar
Lower profile?
at the tire sizes are 195/50/15 and 205/50/15 which is the lower profile tire? 195 or 205
Old Jul 25, 2009 | 07:21 PM
devon9832's Avatar
they r the same profile...... u have u get a smaller sidewall size for lower profile... like a 40 or something
Old Jul 25, 2009 | 07:28 PM
exninja's Avatar
195 and 205 are the tread width. If you want a lower profile you should get bigger rims.
Old Jul 26, 2009 | 02:35 PM
do they make a lower profile in 15'' though? what brand name?
Old Jul 26, 2009 | 04:07 PM
CSVTour's Avatar
Heres a tire size calculator that ive used in the past.
http://www.miata.net/garage/tirecalc.html
Old Jul 26, 2009 | 08:41 PM
Ackermann's Avatar
In the tire sizes the first number is the section width and the second is the sidewall height as a percentage of the width. The third number is the rim size.
So for example a 200/50/15 would be 200mm wide, 100mm sidewall, and fit a 15" rim.
For visual purposes the 195/50/15 will look lower profile, but only by about 5mm radius.
Old Jul 26, 2009 | 08:42 PM
Ackermann's Avatar
Old Jul 27, 2009 | 12:13 PM
DaBuzzard's Avatar
QFT (twice even )
The 195 50 will be a bit shorter AND a bit narrower than a 205 50
You can likely get down to a 35 profile on a 15" rim but why? The tire will either be too wide for the rim (and handle like crap even if you manage to get the bead to seat) or too small in overall diameter (and look like crap).
Get some 17" or 18" rims and tires if you want to go low profile, get the looks and the handling at the same time.
Old Jul 27, 2009 | 03:57 PM
I just bought brand new 15'' motegi sp10 rims. they look fine now. I was just thinking about a low profile, but they would look like **** because they would look extremly small. they're not bad looking. theyre pretty big because a few people had asked me(before looking at the tire size) if they were either 16's or 17's and i told them they were 15's. they said they looked good. plus i want going to go to 18's anyways. i was only intrested in the 16's but when i look them up, there was virtually no VISUAL difference between the 15's and 16's.
Old Jul 27, 2009 | 05:18 PM
DaBuzzard's Avatar
Yeah, 15"'s with low pros is going to look like one of those low riding hydraulic hopper cars - without the low riding part - wheel openings are going to look HUGE.
Old Jul 28, 2009 | 02:18 PM
so ill just stick with the standard
Old Jul 28, 2009 | 02:20 PM
PSHHH's Avatar
low profile on a 15 will look pretty rediculous....why would u even buy aftermarket 15" ?
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
