Maximum Useful HP for Street/DD
I'm sure this topic has been covered in some comments somewhere, but I'd love to hear from people with some experience.
Before I go into my specific details, my main question is: if all I ever do is use it as a DD and occasionally some mild street pulls on stock width tires, how much horsepower is necessary? Will the average driver get any benefit going from 350 to 450 hp? For any drivers with DD experience who have went over the 350hp mark, was it worth the time/money?
Me Specifically
To start with, I'm in the process of purchasing crashher0's sedan. If you're not familiar with it, here's his background story/build:
https://www.cobaltss.net/forums/08-1...thread-308136/
In summary, he started to build the car with a goal of 500hp. When he ran into trouble getting an f40 set up with the car, he never finished it. That being said, it's a Gen 3, fully set up with an s256et stage 3 kit, fully bolted, tuned, etc.
In my opinion (though I've never built one over 350 hp myself), with pistons/rods, 5th injector, and cam, it should be capable of 450+. However, I'm still on stock tranny. Is there any benefit to me aiming for that higher hp? He has such a nice start, but I will 500 hp be a total waste in my car? It's currently tuned to around 350 hp @ 23 psi until it gets completed. Should I just be content?
Just looking for opinions and experience from DDs
Me Specifically
I'm at 481hp but swapped to a 4.05 LSJ trans i ran it for a year with no trans issues. What i recommend is find a good middle ground between spool and max power. I think running a 256 at only 350hp is a waste but also the spool is way smoother than the k04 so it wont shock the trans with torque the same so on a good tune even in the 400hp range it'll be safer
With a good tune you'll be fine. Im 100% stock gen 2 engine so you'd think the gen 3 can do at least that
I'm running the s256 stage 3 kit from zzp in an auto hhr ss 08 gen 2 tuned to 405 with boost limited in 1st to 12lbs. I've had no issues since april. Not a daily driver, I would be in trouble if it was. Too much fun!
In the spring I'll be going to the dyno again with a couple more mods still stock block until my build is done. I'll try to get a tq reading next time people have been asking about it and all i saw was minimum 402
I'm assuming you're still on stock internals? If so, you guys are giving me hope! Who are you tuned by, if I may ask?
f23, but potentially want to get zzp 2.4 clutch kit to do a SS turbo f35 swap. Because lnf and lsj f35's have different final's right? (not trying to thread jack)
Thanks
Then you would be going the wrong way with 4.45 gears. Stock lnf is 3.82, lsj 4.05, 4.45 comes from Saturn trans I believe. 1st gear is super short in a 4.45 trans. The 4.45 gears take some load off the trans to help it live. Plus they can improve acceleration.
Many rwd cars go from say 3.23 gears to 3.73 gears to help 1/4 mile times. Same principle on our fwd cars.
But if shorter gearing is easier on the transmission, and will increase longevity. That's a good thing to know, and would make for a good reason to shorten up the gears. I suppose it would make sense that shorter gears builds less torque on the shafts? because it allows the engine to rev more freely?
Think of it as a small gear moving a lever. The 3.82 is a small lever so it puts more stress on the gear vs the larger 4.45 gear which puts less stress on the gear. I've also noticed that the 7163 comes into boost smoother than the torque spikey k04. I'm interested how much i can get my LSJ 4.05 trans to hold next year.
Looking forward to your build you have coming up.
Just to get to the orginal topic...If I remember reading correctly, ZZP found the rods in the LDK to be a weak point and were breaking around 400whp.
360whp+ is plenty for my daily summer driver. I had a bigger turbo and ended up selling it after getting my E tune dialed in. Plenty of fun for what it is.
But if I were in your scenario I would throw some forged pistons/rods in,cams and opels, crank the boost on that 256 and let her eat.
Appreciate all the insight. The only thing limiting be from doing it up right is the transmission. I'm not sure I'll have the money to finish the engine build and upgrade the tranny. Scared to crank up the boost and hp on the stock tranny. Iv heard stories of 450+ hp on stock, but that's a little scary. With conservative driving, a good tune, and the 256 being a little smoother boosting, what's a safe amount? Can't afford to break my DD.....
Faulty Connecting-Rod Bearing Causing Engine Failures in GM Four-Cylinders ?*News ?*Car and Driver | Car and Driver Blog
