Maximum Useful HP for Street/DD
Old Nov 26, 2015 | 10:53 AM
mississippisunburst's Avatar
Originally Posted by dgascho
Thanks for help. Should've clarified, Mississippi are you stock?
Stock internals, tuned by term2. Tune was done with the auto's life span in mind.
Old Nov 26, 2015 | 12:09 PM
colodude18's Avatar
One thing nobody has mentioned is grip. To effectively use 400+whp you'll need to have a decent rubber budget. I can put down my power without much issues but it takes NT01's, 800 bucks a set that lasts no more than 6,000 miles. And since you're in Indiana, you'll also need a set of winter tires unless you park it for winter.
Also, having 450+ hp doesn't man it makes your car unsuitable as a DD at all. It's not like an on/off switch. You can dose the power pretty well with your right foot so you can still accelerate pretty fast without going WOT. Just my thoughts
Old Nov 26, 2015 | 12:42 PM
dgascho's Avatar
Of course a very good point on how you drive. I guess I don't have experience at 400+, so I'm just curious if I can drive it conservatively enough to keep it alive. In a couple years I'll have the time and money to finish the build correctly to safely run 450-500. In the meantime, id like to use a little more of the 256's potential if I can do that without destroying something
Old Nov 26, 2015 | 08:45 PM
SR Tech's Avatar
https://www.cobaltss.net/forums/2-0l...an-lnf-311534/
I just remember reading this thread and based my info off of that
Old Nov 26, 2015 | 08:52 PM
KMO43's Avatar
The more power you have the less you have to use. Half throttle i can beat most civics
Sean Cummings
Mar 9, 2018 12:26 AM
thewafflesareburnt
Feb 14, 2016 07:30 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
AKillEaze
Wheels and Tires
17
Nov 17, 2015 10:36 AM
ckt
Oct 26, 2015 05:47 PM
