Mobil 1 vs. Royal Purple
#102
This gentleman answered your question the best he could.
#103
I just changed my oil to RP and I hope in did the right choose. What you guys think? They are so many Oil Company’s out there competing with each other. That all I want is the best stuff for my car.
#104
honestly.. none of you are gonna really "FEEL" the difference because mobil 1 and RP are very good oils...
but if you were using Pinnzoil or **** oil like that... you would prolly notice a difference switching to a class 4 synthetic like RP
#106
I had to change my oil today so I drove over to advance auto... looked at back of both royal purple and mobil1<which I've always used... I prolly would of bought r/p just to try but I'm too hard on my car for it blow up cuzz I didn't put the "factory specified correct oil" in and blow the motor.. my srt-4 which I dont know if was factory filled with mobil1 but at 1800 miles had mobil1 Turbo's break the oil down a hell of alot faster then the ss/sc could ever think of and never had a problem ...well engine wise ... wiring was what killed my srt
#107
Is M1 good? Yes it is but it's not AS good as RP
#108
#109
so i went looking and multi window searching for anything at all about mobil 1 being group 3 and nothing not a single real article said anything. There were some forums like ours that tried to argue with no proof or links and sites that tried to argue the '1' in the name mobil has but not a single press release or news article against mobil saying it wasn't fully synthetic and not a group 4 oil.
#110
all I have to say is royal purple does make my ss feel a little more free.
And just because gm recommends mobile1 doesn't mean squat. They probably own part of mobile1.
They also recommend dexcool. And that stuff is highly coorosive to alluminum heads. I'm getting mine flushed and putting in Peak.
#112
On most sites they relate the "service number"., to an actyal number. They are API ,American Petroleum Instite", gradeings. They will give you the TWO LETTER oil designation as you see it on any, and every, bottle of oil. The one site I found was fairly current as they were talking about GL5 which won't be released till next year, 2011. As I understand it the NUMBER should tell you more about the ADDITIVES that EVERY oil contains in varying combinations and quantities. Fact is MOST synthetic starts from the same base stock with the only differance being in the additives. The same as MOST gasoline works the same with MOST brands of gasoline that come out of the SAME storage tanks and have their additives added as the tanker loads the product and as determined by a computer the driver has to program according to the loading sheet. As a driver for a 3 truck owner I delivered to so many branded stations I can't remember them all.
Here are acouple of sites I found. for the oil question.
http://www.amsoil.com/storefront/sso.aspx (Amsoil's recomendation and what I'm using)
http://www.upmpg.com/pdf/api_motoroil_guide.pdf
http://www.api.org/certifications/en.../new/index.cfm
Happy reading.
Happy reading.
#113
I'm in the same dilemma but I think with the new HPS RP with Synerlec will prove far superiority from Mobil 1. Here is a video of the demonstration.
[URL="http://www.youtube.com/watch?v=8dEFGJqpCMY&feature=feedu"[/URL]
My doubt is, in that test which RP performance much better than the others is because they are not using Mobil 1 Extended Performance instead just the normal/common one.
#115
Got this off of the net: (http://micapeak.com/info/oiled.html)
Brand VI Flash Pour % ash % zinc
5W-30
AMSOIL* 186 478 -67
Castrol GTX* 160 410 -35 1.35 .12
Chevron Supreme* 167 410 -38 <1
Chevron Supreme Synt.*169 468 -49
Exxon Superflow HP 148 392 -22 .70 .11
Havoline Formula 3 158 420 -40 1.0
Mobil 1 165 445 -65
Mystic JT8 161 390 -25 .95 .1
Quaker State* 155 405 -35
Quaker State Synquest*168 450 -58
Red Line 151 455 -49
Shell Fire and Ice* 167 405 -35 .9 .12
Unocal 151 414 -33 .81 .12
Valvoline All Climate 135 405 -40 1.0 .11
Valvoline Turbo 158 405 -40 .99 .13
Valvoline DuraBlend 162 415 -38 <1.5 .125
Valvoline Synthetic 160 435 -40 <1.5 .12
I personally use Amsoil since it's basically the #1 synthetic, although I haven't seen many tests about RP.
5W-30
AMSOIL* 186 478 -67
Mobil 1 165 445 -65
#118
Pennzoil Ultra 5W30 is what I've switched to since 12K mi
VI 169
Flash Pt 435F
Pour Pt -49F
But it's not just these #s alone to consider.
Found this interesting observation from a TC owner on another board:
It's actually based on UOAs...M1 vs Pennzoil Ultra!!
Mobil 1 or Pennzoil Ultra??? - AR15.Com Archive
Originally Posted By sq40:
Mobil 1 has always worked well in my engines. Try running a Turbo i4 at 18psi for 225,000 miles on anything else..
I have been running M1 in my daily drivers for years,but after a few less-than-stellar UOAs in my LNF Ecotec, I decided to switch to Pennzoil Ultra since the UOAs I've been seeing for that have been impressive. I haven't been driving the Cobalt during the winter, but did make the switch in my LS2 as well even though (with the exception of the Sodium, which we're speculating was from the previous owner's oil) the previous UOA looked good
VI 169
Flash Pt 435F
Pour Pt -49F
#120
Amsoil 100% synthetic is exactly that.
Amsoil XL series is also "synthetic" like Mobil 1 is. But not a true synthetic. Same goes for the the new Amsoil OE line of engine oil.
For the LNF turbo, Amsoil 100% is the only Amsoil product that should be used.
#121
Well if you want facts just go to the website AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases if anyone ever needs some just e-mail me at kingmanbc@aol.com and I will get you some prices, the oil I use and recommend is the 0w-30 signature series for our cars.
#124
There is alot of diffrent oils and opinions out there. Alot of good oils too.
Personally, I use Mobil 1 5W-30 because that is what the Owners Manual
calls for. I'm not a chemist, and I don't know tons about Oil and this and
that with Oil. I'm not saying the other options are bad. I'm just saying that
Since my owners manual calls for Mobil 1 5W-30, Mobile 1 5W-30 is what it
gets. Now mind you the owners manual DOES say that other oils can be used
provided they meet certine criteria. I can't remember all that right now, youd
have to look. If you don't have an owners manual, one is avalible online for
free from Chevy's website in Adobe .pdf format.
So basicly,
It says to use Mobile 1 5W-30 so that's what I use.
