Mods
Old Jan 17, 2007 | 08:32 PM
JMH's Avatar
JMH
Mods
As I get more familiar with this site, I continue to be amazed by the radical aftermarket modifications made to these cars............and they're all pretty new!!
Given the FWD architecture, I have a hard time keeping the thing in a straight line under hard acceleration as it is? First gear already turns the pricy Pirrellis into GOO.
How are you guys able to put all the extra power to the ground?........and if you can, how do you get rid of the cars front end "hunting" all over hells' half acre in 2nd and 3rd roll-ons? It's F'ing scary somtimes. I'd give my left ******** to have this car driven by the rear wheels; the powertrain deserves it.
I love my car (don't get me wrong), but my old Mazda Miata would run circles around my SC on a twisty road despite the power difference. The Miata architechture could handle 300bhp without a problem, my Cobalt struggles with what it has?
I guess I got the RWD blues.
Old Jan 17, 2007 | 08:51 PM
BlilBT's Avatar
1st) Get rid of them crappy Pirelli's they dont grab ****!
2nd)look into traction bars, Strut bar & sway Bar!
Old Jan 17, 2007 | 09:38 PM
XM15's Avatar
Also, look into getting engine and tranny mounts. What's the use of all the ponies under the hood if you can't put them on the ground?
Old Jan 17, 2007 | 09:43 PM
Red2.4SS/SC's Avatar
and dont forget the ingals stiffy that seems to be a popular item of choice
Old Jan 17, 2007 | 09:48 PM
JMH's Avatar
JMH
I appreciate the info.........but whatya mean crappy P-Zero Rossos? They're OEM for the Ferrari 360/460?. Ferrari (I suspect) has pretty picky clients!
As for traction bars though, I'm not framiliar with how these are installed on a FWD car?
The stock anti-sway bar/bars are sufficient for my needs as I don't find the body roll to be excessive while cornering. -It's the "puppy looking for a place to ****" feeling when I apply agressive but linear throttle to the chassis in a straight line. It's disconcerting..............the only way I can describe it is driving in the prarries and catching some heavy wind broadside (the steering wheel hasn't moved but the car has).
Any info on traction bars?
Ah yes .......the stiffy. I was looking at that earlier and combing the posts about it.
It does sound like it helps with a number of issues. Do you have one ?
Old Jan 17, 2007 | 09:50 PM
BlilBT's Avatar
Dude the Pirelli's we have Suck, You can Not Compare our tires to a Ferrari ... Not even close to the same size! Go 1 Inch wider & you will see a difference! Plus Like above, Ingalls & Mounts. My tires Now Blow away, The Pirielli's I had<< Still have Brand new Mounted on rim in My garage!
BWoody has the Bars!
Old Jan 17, 2007 | 09:51 PM
yellowcobaltss05's Avatar
Be the first to convert your balt to RWD!!!
Old Jan 17, 2007 | 10:34 PM
JMH's Avatar
JMH
Actually, P-Zerro Rossos @ 215/18/45 are direct OEM replacements for the front tires of both Ferrari's I've mentioned above. They were initially developed for these cars specifically. The compound however, is identicle regardless of size (the rears being larger obviously) on the Prancing Horse Automobileee. That's why they're so expensive to replace. Apart from our Cobalts', Ferrari and Volvo are the only marks that use this width/aspect ratio/combination in an OEM application (on one model-the Vulva S5) .
So you know.
Jeepers, I'm tempted.
Use the rear trans-axle from the vette, and a carbon-fibre torque tube.
I wish it was that easy!!!!
Old Jan 17, 2007 | 10:47 PM
Delta2.2's Avatar
So you know.
dude go for it. make us all in aww of ur car.
Old Jan 17, 2007 | 11:08 PM
JMH's Avatar
JMH
No problem. Gotta a line on a C-6 tranny and $40,000?
Old Jan 18, 2007 | 01:05 AM
BlilBT's Avatar
So you know.
Well you asked, I told! So do what ya want, But I got New & I can tell you with upmost confidence that My new rims & Tires Blow away the Pirelli's!
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
