My sunroof!!
Old Jun 1, 2010 | 10:20 PM
chingajose's Avatar
My sunroof!!
yeah so today im shutting my sunroof and when it was going down it made a weird sound. so i look at it the one side wont shut all the way. so i had to tape the side it wont go down since it is supposed to rain. so how much do u think it could be to get fixed?
Old Jun 1, 2010 | 10:25 PM
reddevil's Avatar
is anything stuck in it ?
does it still open ?
Old Jun 1, 2010 | 10:29 PM
Maupin SS/SC's Avatar
had the same problem its gonna be a few hundred to fix out of warranty the track brakes. i could see the problem if you watch in the track and see where it hits. take it in and ask
Old Jun 1, 2010 | 10:30 PM
Berto09ss's Avatar
warranty??
Old Jun 1, 2010 | 10:32 PM
RedSS87's Avatar
The track lock broke as it did on my girlfriends 06 LT a couple years ago from the sounds of it. I was lucky it was covered under her warranty.
I was able to take a screw driver & slide the lock on the track forward about 1 inch & then it would shut but every time you open it you will have to do this.
By memory there is a little tab that locks (it slides with the window under normal opperation)the suroof when it shuts and mine broke so when it's trying to shut it actually holds the one side up and wont let it shut, so look at the side that is binding and look for this tab and slide it about one inch forward then try shutting the sunroof.
It suck because to fix it you have to replace the whole track and I think there about $200 aren't they but I could be way off
Old Jun 2, 2010 | 04:27 PM
chingajose's Avatar
ok so when i shut it there was a sound of a clicking sound. so after that happend my driver side back part of the window wont shut. and when u press down it seems like there is something in there. so i should be able to get it to shut by doin wat?
Old Jun 2, 2010 | 04:29 PM
chris88z24's Avatar
Hmm, mine clicks and clacks all the time, but it still opens and closes.
(knock on wood)
Did you open it back up and see if it's binding on anything? Sometimes **** gets stuck in there, I had a bunch of rocks and road debris inside of mine before.
Old Jun 2, 2010 | 05:00 PM
chingajose's Avatar
when i shut it and look in the inside of the sunroof. the side that isnt working right the inside isnt lined up like the working side.
well i knew where ur talking about. the piece that slides for the lil screw to go in. well i pushed it forward and it moved a lil. well i pushed a lil hard and it snapped part of the piece. so i was hanging now but it does go in flush to the roof now. lol oops. well i just wont be using my sunroof anymore now. i just didnt want to shell out 200 some dollars. so u think since i snapped that piece it will cost me more to fix it? well anyways im happy it is flush now. im not worried. thinking if i should fix it before i trade it in or not? thanks fellas for all the advice and info definately appreciate it.
Old Jun 2, 2010 | 05:50 PM
RedSS87's Avatar
lol ouch sorry to hear man. its gonna need a new sunroof rack and there about $200. Id prolly fix it if ur gonna trade it back in. good luck tho
Old Jun 2, 2010 | 06:38 PM
theres a lock you have to hit where the arm goes up and down in the track as said before hit that and it will stay down all the way as long as you dont open it again.
Jan 12, 2016 12:01 AM
chefhhr
Oct 26, 2015 10:36 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
jthwjde
Sep 7, 2015 09:24 AM
