need crank case relearn performed
Old Nov 21, 2014 | 11:04 PM
goeckeritz123's Avatar
hey guys im replacing my cps and im going to need a relearn performed wondering if anybody could help me out. pm or text 8013898500.... thanks guys
Old Nov 22, 2014 | 11:33 AM
Jesse's Avatar
Do you have access to someone with HP Tuners? They can do it with that. Otherwise have the dealer do it.
Old Nov 22, 2014 | 11:47 AM
TStone's Avatar
Relearn the crank case........ hmmm...... that's an interesting one.
Okay i'm done. It's called a "Crankshaft Position system variation learn". Some people claim you can do it with HPT, i've never had luck. Best bet would be take it to a dealer. Should take them 20 minutes max.
Old Nov 22, 2014 | 12:04 PM
07blackg5's Avatar
Slobodan Milošević
You can do it with an interceptor. Ive done it
Old Nov 22, 2014 | 12:46 PM
Wish I had hptuner myself so I didnt have to search around for someone with it.... is it true somewhere like firestone can perform this?
Old Nov 22, 2014 | 12:49 PM
Jesse's Avatar
Anyone with a GM Tech II can do it.
Old Nov 22, 2014 | 01:08 PM
Some generic scan tools like the snap on one will work too
Old Nov 22, 2014 | 09:54 PM
Oh sweet I kno someone with a snap on.
Old Nov 24, 2014 | 01:16 AM
Replaced cps tonight. I went to start and it idles fot about 5 sec then dies pulling code for cps. Will the relearn fix this
Old Nov 24, 2014 | 01:21 AM
Yes lmao
Old Nov 24, 2014 | 01:25 AM
Dam car isn't happy lately. I was hoping it would at least start with the new sensor. I dont understand why it needs a relearn. You cant change the position of it theirs only one way for it to go in
Old Nov 24, 2014 | 01:27 AM
I think it may be because each sensor is of slightly different resistance. Not positive
Old Nov 24, 2014 | 01:31 AM
So is it normal for the car not wanting to run after replacing that sensor?
Old Nov 24, 2014 | 01:32 AM
Whats the code you have
Old Nov 24, 2014 | 01:33 AM
Also if I cant keep the car running will the relearn process still work
Old Nov 24, 2014 | 01:37 AM
I wanna say it was 0336 0r 0335
Old Nov 24, 2014 | 01:38 AM
Google it
Old Nov 24, 2014 | 01:41 AM
You could ohm test the sensor for starters
Old Nov 24, 2014 | 01:43 AM
Did your car do the same thing before you replaced the sensor? Why did you replace it?
Old Nov 24, 2014 | 01:49 AM
It would run for about 10 mins then die. And I would have to wait for about 15min to start it again. If I stayed cruising it would stay running but rpms would hickup randomly. But as soon as I would stop the car died. I also was throwing codes for maf I replaced that.
Whats weird is I just had the dealer replace my fuel pump now this
Last edited by goeckeritz123; Nov 24, 2014 at 01:49 AM. Reason: Automerged Doublepost
Old Nov 24, 2014 | 01:52 AM
The wires looked good same with the connector.
Old Nov 24, 2014 | 01:56 AM
Do you have a multimeter?
Old Nov 24, 2014 | 01:59 AM
Yes. Also the code reader I have has some options for mls and a few other features. But I guess I cant perform those without the car running
Old Nov 24, 2014 | 02:00 AM
If I have to check the voltage ill need to get back under their and remove the starter so I can access it
Old Nov 24, 2014 | 02:12 AM
You have to measure the resistance to make sure the sensor is good, but that is a bitch of a job to do just for that. Its odd odd because the new sensor made the problem worse.
