Need information on A Arms
Old 05-09-2017, 11:14 AM
WillisW's Avatar
Old 05-09-2017, 11:15 AM
royce777's Avatar
just check to see if it measures the same as the other side (or really close cause it prob wont be exact)
Old 05-09-2017, 11:20 AM
cluelessk's Avatar
Originally Posted by WillisW
I replaced the strut before cause I thought that's what was wrong but it wasn't. I asked the seller if it was an they said yes it's the correct one. I'm going to be checking the knuckle today. I'm getting tired of pulling the same wheel off day after day. What is your measure for your wheel to center? So I can compare the two
A body shop should be able to get you the measurements. Might only be able to measure to the ball joint though.
Old 05-09-2017, 11:42 AM
There is no way that is the right axle, your axle boot should not be like that.
Or something is way off, I'd check engine and trans mounts and your knuckle and stuts
Old 05-15-2017, 07:39 PM
WillisW's Avatar
i replaced that strut already I'm going to drop the engine cradle to get a better look at it something has to be off to cause a cv axle failure an yes i was looking at the cv axle in the picture an it does look really off looks like the knuckle was pulled out before i even put power to it.
Old 05-16-2017, 12:36 AM
ItalianJoe1's Avatar
Is the axle the same length as the other side? They should be identical.
Old 05-16-2017, 10:16 PM
WillisW's Avatar
top of the engine cradle
bottom side of the cradle
ripped cv boot but all bearing are theyre
the cv after the cradle is removed looks better an proper
Old 05-16-2017, 10:22 PM
WillisW's Avatar
Pulled engine cradle out an the cv looks right an so does wheel alignment
Old 05-17-2017, 09:06 AM
royce777's Avatar
weird. its going to be a process of elimination now.
Check:
-trans mounts
-engine mount
-intermediate shaft
-knuckle/hub
Also do a very detailed visual inspection of anything that looks weird underneath. Make sure the car is supported very well before crawling underneath
Old 05-17-2017, 01:04 PM
WillisW's Avatar
Check:
-trans mounts
-engine mount
-intermediate shaft
-knuckle/hub
underneath
The engine an transmission mount bolts came out nice an smoothly an the bolts are straight as well so im going to rule those out axle is straight
Old 05-17-2017, 01:05 PM
  #36
WillisW's Avatar
Might be the knuckle if it is then I will replace it too I already got a brand new hub so that will go in too
Old 05-17-2017, 01:26 PM
  #37
royce777's Avatar
Check the upper engine mount on the passenger side. Usually a knuckle will break before it bends. When you installed the axle did you make sure it was seated all the way inside the intermediate shaft? Make sure there is no damage to the intermediate shaft bearing or bracket.
Old 05-17-2017, 01:42 PM
  #38
WillisW's Avatar
The engine is being held up by the upper engine mounts so if they were damage I'm pretty sure they would have failed an yes the axle was in all the way. I will check the bearings an brackets when I go back to the car. Does the engine cradle look bent at all to you?
Old 05-17-2017, 03:15 PM
  #39
WillisW's Avatar
Engine Cradle is Bent by 1/16 of an inch isn't very much but enough to put the a arm out by half an inch
Old 05-17-2017, 06:21 PM
  #40
WillisW's Avatar
At an auto wrecker engine cradle is 595 brand new 1300 from gm :/ this **** an't cheap is it
Old 05-18-2017, 12:05 AM
  #41
cluelessk's Avatar
Check your local classifieds for a someone parting a car our.
Old 05-18-2017, 04:17 PM
  #42
WillisW's Avatar
The ones I've found are front end damage so I'm not going to risk buying a bent cradle
