Newbie here
Newbie here
Hey everyone I just brought my 07 SS Supercharged 2 weeks ago... Just wondering what's stock factory boost because I'm hitting 15 psi with out a problem.... I've read that some ppl are hitting from 3psi to only 13psi is this a problem.. Maybe the car isn't stock or something Idk just need some info. I'm in New Jersey so does that play a factor?
Ok sorry I'm late with this one... but ok ill post pics up later because I'm at work.... and which pully whould have a number on it the supercharger pully??
Fail Less.
A stock pulley will have no bolts, it is pressed on to the s/c shaft. If you have 4 or 5 little bolts holding the pulley on to a hub, then its been changed.
Also, If you have an aftermarket pulley, you should check to see if it has aftermarket injectors. Stock plastic clips on the injectors will be green.
Ok thanks to every one that helpped me with the info... like I said I will be putting the pics up later today... what if I don't have the pully what could be the other reason why I'm boosting at 15psi
Stock you wont't harm much. Pullied/custom tuned is a different story.
I logged 14.5psi on a 34*F day once back when I had the stock pulley, and GMS1.
Maybe my peak boost rose a little higher, because I was reving to 7k?!? Who knows.
You know what I forgot to tell you guys I have a hole in my flex pipe could that be one of the reasons why I'm boosting at 15psi I'm taking the pick of the pullies now
Are you in Plainfield, IL?
We have a Chicago area meet coming up on Sunday in Bolingbrook. If you want to come out, the guys can look it over and figure out what all you have done. Let me know if you want more info.
