no coolant temp displayed
did you bump, unhook or break your coolant temp sensor??? i know on the l61 its located on the water manifold on the drivers side, right bellow the header. not sure if they run 2 on the lsj, but i know there is one on the top of the head at the front by the fuel rail.
I couldn't find the location in the chilton manual for the 2.4L, but here is the 2.2L and 2.0L locations. Hope it helps out. Being that it's basicly the same engine insofar as blocks go anyways it should be in the same location.
Location on 2.2L --Shown removed from its location on the bottom of the image
Location on 2.0L --Marked with the number 3
z28addiction
Sep 28, 2015 12:03 AM
