Noise Diagnosis - 2008
Old Nov 29, 2013 | 01:57 PM
rybalt's Avatar
2008 Cobalt.
Has become noisy, like a revved up sound (errrrrrr, errrrrrrr) maybe like the car grew some ***** but thats not the case.
It only occurs when you acclerate past 15-20 mph. Coasting at like 35-45 its loud and decreases in resonance as the car slows and comes to a stop. Comes from the front but cant tell if its from engine or vibration.
It does NOT occur when in neutral/idle or park when you rev it up (RPM's never go past 4000 when I do that, kinda stuck there?). I first thought muffler/exhaust but I figure that would be loud when just idle as well. If I am just rolling in idle drive I dont hear anything that would indicate the tires rotating... it only occurs when getting up 20 mph and above.
Anyone want to take a stab at a guess?
Old Nov 30, 2013 | 09:41 AM
dsmnutz's Avatar
Tires or wheel bearings? Always hard to diag a noise you can't hear in person...
Old Nov 30, 2013 | 03:51 PM
rybalt's Avatar
I understand its impossible without hearing it. But give it a shot.
AS far as wheel barings, I thought of that as well. Is that a major fix? $$$$
Old Nov 30, 2013 | 07:37 PM
dsmnutz's Avatar
Wheel bearings aren't hard at all to replace. I would go with GM ones...shop around online, gmpartsdirect.com, crateenginedepot.com, even amazon or eBay.
Old Nov 30, 2013 | 08:01 PM
ItalianJoe1's Avatar
Easy way to check wheel bearings: Jack up the car (lift makes it faster) and spin the wheel by hand, feel the spring or directly on the knuckle. If you feel any rumbling/roughness, the bearings are toast. Pretty common for them to fail and no it's not a big deal to replace at all. My record is about 10 min start to finish for a front wheel hub but I had my tools pretty much laid out ahead of time.
Old Nov 30, 2013 | 08:55 PM
rybalt's Avatar
Ive been reading online about the bearings/hub and it sounds kinda like what other are describing.I will take a look tommorow afternoon.
....if its just the bearings, do you have an idea about a ballpark figure on replacement by a mechanic shop?
Old Nov 30, 2013 | 11:53 PM
Labor is under an hour for the fronts, and the part should be under $100 retail. I'd say $200 for one would be kind of a high estimate.
Old Dec 2, 2013 | 06:21 PM
rybalt's Avatar
It was a wheel bearing that was shot. All fixed, noise is gone...
Good call dsmnutz!
Old Dec 9, 2013 | 12:41 PM
BANephew1S's Avatar
Have been having this same problem, I assumed it was some kind of bearing or the like because of lack of noise at idle. If I do not immediately fix, could it cause more damage to anything else?
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
