ODD question of the day....help please!!!!
Old Mar 26, 2008 | 05:17 PM
DoubleLP's Avatar
So I have a ZZP midlength header and downpipe with the Magnaflow cat, and the Magnaflow catback bolt on exhaust.
Now when I first installed everything it sounded nice with a deeper tone and no raspy, fart-can sound.
However, once I put my wideband O2 sensor in where the extra bung is in front of the cat after the 1st O2 sensor off the car...my exhaust now sounds like a raspy, fart-can when under medium to full acceleration.
What would cause this? Is it the wideband O2 sensor? And is there anyway to fix it??
Please help me get rid of my fart-can sound.
Old Mar 26, 2008 | 05:18 PM
XM15's Avatar
Buy a V8.
Not sure.
D4u2s0t's Avatar
sounds like something either came loose, or the bung wasn't welded properly
Old Mar 26, 2008 | 05:19 PM
bluecobaltss06's Avatar
My car is kinda raspy when its cold. Let the metal heat up drive around the block a few times then see how it sounds.
Old Mar 26, 2008 | 05:22 PM
DoubleLP's Avatar
Still does it after it is heated up. And it does not sound like anything is loose, which would give more of a tinny sound.
Old Mar 26, 2008 | 05:37 PM
Banzai2.4's Avatar
did u bag on it when u first got it?? or did u give it the 500 km babying period??
Old Mar 26, 2008 | 05:38 PM
DoubleLP's Avatar
babied.
Old Mar 26, 2008 | 05:39 PM
07SSCharged248's Avatar
well in my old car i needed to make a thin gasket for the o2 bung... but that was a 72 monte so no real comparison can be made...
Old Mar 26, 2008 | 05:42 PM
06_SS_S/C's Avatar
probably got a leak somewhere.
Old Mar 26, 2008 | 05:44 PM
DoubleLP's Avatar
Hmmm........maybe. I tried tightening the wideband O2 sensor but I can't get anymore on it.
Click on "Clip 1", it should be closer to that sound then what I have now:
http://www.magnaflow.com/02product/s...rican&id=5584#
Old Mar 26, 2008 | 05:45 PM
06_SS_S/C's Avatar
might be a leak somewhere else, gasket could be bad or something
Old Mar 26, 2008 | 05:48 PM
DoubleLP's Avatar
Yeah true. I have it booked in with Midas on April 7th, but if I can avoid going I will.
Old Mar 26, 2008 | 05:49 PM
06_SS_S/C's Avatar
did you use the hardware ZZP sent you?
DoubleLP's Avatar
Yup.
Pickles's Avatar
You may want to get under there and retighten the header and header/dp bolts. Over time, they may have gotten a little loose after break in, and the gaskets may not be mating up quite as tightly.
Old Mar 26, 2008 | 05:51 PM
DoubleLP's Avatar
You busy tomorrow??
Old Mar 26, 2008 | 05:52 PM
07ss_PJ's Avatar
check the bolts. from what i hear the ones zzp sends you are *****!
06_SS_S/C's Avatar
Originally Posted by DoubleLP
Yup.
thats probably your problem. the washers they send out are aluminum. here is what they look like after a month or so:
Go out under the car if you can, feel around (when the car is cold ) and see if you can feel the washers. If they are like this you should be able to feel that.
If they are, go out and buy 1/2" grade 8 bolts, nuts and washers and replace the crap they sent ya.
Old Mar 26, 2008 | 05:53 PM
DoubleLP's Avatar
Now these are the ones that attach the downpipe to the header and the catback exhaust right?
Pickles's Avatar
You busy tomorrow??
Nope.
Old Mar 26, 2008 | 05:54 PM
DoubleLP's Avatar
you are not working neo01? Feel like helping a brother out??
06_SS_S/C's Avatar
Yep, both.
You will need 4 set of bolts/washers/nuts. 2 for the dp/header and 2 for the catback/dp.
Pickles's Avatar
Well I am working. I meant not busy other than that.
Old Mar 26, 2008 | 05:55 PM
DoubleLP's Avatar
Ahhh ok! What time are you off?
Pickles's Avatar
I'm home by 4:30 I can have the garage ready for you.
