Oil cooler?
Old Apr 30, 2016 | 07:01 PM
ItalianJoe1's Avatar
Originally Posted by ECaulk
Is the oil cooler different on the 2.4 vs the 2.0?
2.0 LSJ, yes. I think the LNF one is similar to the LE5 though. The LE5 one is much smaller than the LSJ one, but i'm not sure if they physically mount different.
Old Apr 30, 2016 | 07:30 PM
chuckie's Avatar
Originally Posted by blueLNFftw
So what do you want?
You want a delete plate?
Can make you one.
Thanks...give me a day or 2 to see if I can find a cooler..i have a few people searching for me...really appreciate it ...will let you know asap.
Old Apr 30, 2016 | 07:38 PM
blueLNFftw's Avatar
You'll have to ship you broken one to NM for it to get made.
It's my buddy; he made mine.
Old Apr 30, 2016 | 07:42 PM
blueLNFftw's Avatar
The LSJ and LNF ones are totally different and will not be cross compatible. I had one of each when making my oil to air plate.
The le5 appears to also be different from both the LSJ and LNF one.
Old May 13, 2016 | 10:29 AM
chuckie's Avatar
Can make you one.
Was told that it cannot be deleted either as the oil still has to flow through where the cooler was..any idea if this is true?
Old May 13, 2016 | 10:30 AM
blueLNFftw's Avatar
You cannot just cap it off.
What I plan to make for you is a plate that has a tube that still allow the oil to pass through and back to the other side.
I could also make you a plate that allows you to run -AN lines to an external oil cooler of your choice.
Old May 13, 2016 | 11:22 AM
chuckie's Avatar
About how much would you charge?
Old May 13, 2016 | 11:32 AM
Cman46290's Avatar
Wouldn't be a head gasket. If it were a head gasket, you'd have coolant in the oil..... not oil in the coolant.
The oil cooler failing internally has much more pressure than the cooling system.... thus it pressurized the oil to go into the cooling system. Id definitely say its the cooler(or at least my first guess). Not a head gasket.
Ive also seen blocks crack and cause the cooling system to fill with oil... but usually on cars that do not have an oil cooler.
Old May 13, 2016 | 11:36 AM
chuckie's Avatar
I had it tested it is the cooler...
Old May 13, 2016 | 01:00 PM
blueLNFftw's Avatar
$160 shipped.
You send your stock cooler to me.
Best bet is -10AN fittings.
Make a loop like to just recirculate or direct to an external oil cooler.
I'm thinking about the whole solid tubing recirculated idea and I don't want to. Without the car in front there is no sure bet the tube won't infere with something.
Old May 13, 2016 | 01:06 PM
  #36
chuckie's Avatar
$160 shipped.
yeah im not going to put an external cooler on it..just more problems...plus im in Canada so I'd ship it to my aunts in New York state to avoid customs issues..i'll let you know asap..ok thanks!
Old May 13, 2016 | 01:35 PM
  #37
advise's Avatar
i have a good cooler only 60k on it switched to a 2.4 block which doesnt use it
make me an offer
pm me your cell ill shoot you pictures
Old May 16, 2016 | 02:25 PM
  #38
chuckie's Avatar
What I think we are going to do for now..is because the leak is internal we will bypass it by hooking a hose to the 2 coolant ports on the cooler...then the oil should only run back into the oil cooler. Perhaps also plug the tubes with jb weld high heat or something.
Old May 16, 2016 | 03:28 PM
  #39
blueLNFftw's Avatar
Hope little chunks of aluminum don't end up in your oil
Old May 16, 2016 | 03:39 PM
  #40
chuckie's Avatar
I hope not too..GM left me little choice my mechanic has no other options, no parts available , they should stay separate in the cooler, just both will be oil. Thanks for the part offer but its risky that my cooler would get lost in mail etc and then I am done, no other options
Old May 16, 2016 | 04:39 PM
  #41
blueLNFftw's Avatar
Advise says he has one....
Old May 16, 2016 | 04:46 PM
  #42
chuckie's Avatar
spoke to him , wrong part.
Old May 16, 2016 | 05:12 PM
  #43
blueLNFftw's Avatar
Email zzp????
Email OTTP?
Old May 16, 2016 | 05:14 PM
  #44
chuckie's Avatar
Originally Posted by bluelnfftw
email zzp????
Email ottp?
?? What?
Old May 16, 2016 | 05:27 PM
  #45
blueLNFftw's Avatar
Did you email zzp and ottp?
They specialize in there care and often have junk laying around.
Old May 16, 2016 | 05:35 PM
  #46
blueLNFftw's Avatar
http://www.car-part.com/cgi-bin/search.cgi
Old May 16, 2016 | 06:03 PM
  #47
chuckie's Avatar
Tried them waiting for reply..
Old Oct 17, 2016 | 11:05 PM
  #48
NathanRhodes84's Avatar
Hello guys,
I am having same problem, 07 cobalt ss/sc 164k and I just noticed oil leaking out of coolant reservoir and oil dipstick almost no oil on it. I changed oil and flushed radiator and all coolant out of the block. Please tell me you guys have something to help me???
Old Oct 18, 2016 | 07:07 AM
  #49
chuckie's Avatar
I ended up connecting the 2 cooler hoses together and the coolant lines together. There are no parts available , if you can have someone make you a plate to cover the ports then that is a fix but not easy. You have to have the little tube removed from the right port so the oil can flow. A real pain in the a$$ makes me hope someone at GM gets slapped in the face.
Old Oct 18, 2016 | 07:35 AM
  #50
Thanks Chuckie I'll be in touch. If there is anything more you can offer and have spare time. Pictures or anything to help please do 908-801-7428
