OK HELP!!! Taking off the SS/SC Wing!
I need help a tutorial or something pics could help to take off the SS/SC wing. I tried searching for anything and could find anything. SO HELP GUYS!!! If you can. Even tell me how to plug the holes with what? I just need major help.
well there is a how-to in here some where that will be good help to you. but first thing you have to do is remove the 4 blots in the turnk that hold the wing on. then you need to get some fishing line and start pulling it threw the gunk that holds the wing on the trunk. this will take some time of course. but be carefull try not to scratch the trunk to much. after you get that off there will be some gue stuck to your trunk so get some gue gone and start removing that. once your done you may need to polish the area a little bit to remove marks that may be left. then wax. for the holse you can use a assorment of things but most people take it to a body shop and have them fill them or weld then and have it repainted and it will look great. good luck man
$320 to have the trunk holes welded shut, smoothed, and repainted the factory color here. Good luck getting the spoiler off as it's a total bitch because of the sticky stuff! I used gray vinyl sticker (used an Altoids can for the rectangular shape) to cover the holes temporarily.
