One Headlight Very Dim
Old Jan 24, 2019 | 10:13 AM
Bearkats99's Avatar
I have a 2008 Cobalt and recently the driver side headlight was going in and out. I then noticed the connector looked like it had melted and assumed created a bad connection. I replaced the the headlight connector harness (three plugs) and that did not fix the issue. I then replaced the connector from the electrical lines that plug into the connector harness and that did not fix it. I am now thinking after more research it must be a bad ground wire or earth wire. The issue is that it appears the ground wire for the driver side headlight is under the radiator overflow tank. I was trying to see how to remove that tank to give me space to inspect the ground wire. Does anyone know if I have to remove the fuse box in order to move the reserve tank? Also, does anyone have any other ideas pertaining to the issue of the dim light?
Thank you!
jeffcollins05
Dec 21, 2017 12:21 PM
ziffbam
Dec 13, 2009 01:09 PM
boostaddict
Nov 6, 2008 01:32 PM
ziffbam
Apr 27, 2008 09:00 PM
FRIARPOP
Mar 27, 2006 11:02 PM
