OTTP mount failure
Old Jul 17, 2012 | 11:17 PM
Dart_SI's Avatar
OTTP mount failure
Anyone else have theirs fail? I saw it when I swapped my trans. Perhaps this is the cause of my trans failing?
Pic is of my rear mount. Front mount looks kinda worn too.
Old Jul 17, 2012 | 11:21 PM
BankerBalt's Avatar
in for ttr inserts! year and a half and still no problems
Old Jul 17, 2012 | 11:22 PM
padlock's Avatar
with OTTP's rep.. im not surprised
Old Jul 17, 2012 | 11:28 PM
Bluelightning's Avatar
Got Bewst?
Old Jul 17, 2012 | 11:50 PM
ebristol's Avatar
Hold old is the mount?
Old Jul 18, 2012 | 12:50 AM
Aleksey's Avatar
Guess I should check mine too, did tranny get warrantied?
Old Jul 18, 2012 | 12:54 AM
OttawaMark's Avatar
OTTP should buy you a new tranny for selling such garbage.
Old Jul 18, 2012 | 10:24 AM
ebristol's Avatar
We need to know how old the mounts were before we start throwing stones.
Old Jul 18, 2012 | 10:26 AM
Omnigear's Avatar
^this
Old Jul 18, 2012 | 10:39 AM
Powell Race Parts's Avatar
Lol @ eBristol. Stone throwing is a forum pastime. Fact is, ott use a very cheap insert. its what he wanted to reduce cost. I see failures with that bushing, and so I wont use them now. I have warrantied some of Otts crap, stuff I did not make, and I dont feel I should make a practice of it. The machine centers on the copied Ott program are not 100% by comparison.
The poly inserts that TTR use wear out ,on their version of the rotated mount I pioneered, and the motor moves on the center sleeve.
some of the problems I have seen can be traced to faulty installs, but thats life as well. Folks like Blazin06SS in Florida are on their V.1 mounts with no issues, and my 5 year old ones have no issues either. I believe 06blackg85ss in NY has my original ones as well.
So far, I dont see a real big issue other than the usual vendor problems well documented here. I can fix these mounts cheaply, but that would require different spacers.
My latest all steel mounts are very different to the billet ones.
Old Jul 18, 2012 | 10:44 AM
aikidoshadow's Avatar
I have the PRS STGII mounts from way back and they seem to be fine. (I can break even the sturdiest of **** too) Ill look into them again after a while, but PRS had always stood behind the OG mounts.
with respect, this mount had absoutely NOTHING to do with your trans failing. Even in its torn state, the mount will move less than a stock LSJ or LNF bushing. In my experience, most transmission failures can be traced to driving modes. Did you not have a series of engine issues? And perhaps you may have been to the drag strip , the autox or the road race track?
Old Jul 18, 2012 | 10:52 AM
Dart_SI's Avatar
Im not blaming the mount for the trans failure, as im right around the power level to break them. The mounts I have were on the car for almost 2 years. I installed them properly too, made I drove around the block with the mounts loose to get the proper "rotation" before I torqued them.
My car has been airborne before (with area47 driving, but that's a different story)
Old Jul 18, 2012 | 10:58 AM
RoadconeTuning's Avatar
just out of curiosity, what do the PRS bushings look like? I've got some mounts i bought from OTTP a few years back and now wondering if i should leave them off the car...
Old Jul 18, 2012 | 11:03 AM
Dart_SI's Avatar
To be fair they worked good when I had them on the car. Im going to go with Powell now tho.
Old Jul 18, 2012 | 11:20 AM
I was just going to have DDM throw them on the car when they put my Hyper Single in the car but i'm going to hold off until i can verify i have the good mounts vs the ones that could possibly fail
Old Jul 18, 2012 | 11:26 AM
Omnigear's Avatar
Aaron might cry and report your post to be deleted
Old Jul 18, 2012 | 11:34 AM
YUP mine fucked up like that too... now every time im on/off the gas i feel the engine move and buck and make click noises doing that.. i'm pissed because i went and swapped out the bushing in it for a new one and same thing already. gonna go the powell route.. very, very soon.
Old Jul 18, 2012 | 11:43 AM
06SS ALL DAY's Avatar
Soooo how much for powell mounts? Lol
Old Jul 18, 2012 | 11:48 AM
TurboTechRacing's Avatar
No, but we will comment now, so thanks for the welcome!
Poly will over time, like any other material show signs of wear, but if ours do, and your the original owner, no problem! Contact us!
We won't blame our mount failure on another company. Johns "original" mounts used that bushing in photo #1. Blame it on install error, or whatever, we dont blame our customers.
ALL members need to closely look at their mounts, as the bushing in post #1, is the same "voided" bushing used in those mounts since day one. (cough) Someone is talking smoke to cover this up. Photos all over the internet show this same Control Arm Bushing insert, even back when the rotated mounts were factory mounts, re positioned bushings.
These post of this mount/voided bushing tearing is nothing new, they pop up time to time, and have for years already. (deleted by mods back in the day) What a poor choice of bushing. They fail in a control arm, why would they work as a tranny mount!
John should replace all of those sold prior to, what 2011? As he has been, and should continue. As he made them, and there were just sold through OTTP. OTTP just resently started manufacturing these, prior to that John made them.
ZZP was smart, THEY were the one that came up to use a NON VOIDED RUBBER bushing... Not John.
Old Jul 18, 2012 | 11:51 AM
Eric you are a smart man.
Old Jul 18, 2012 | 11:52 AM
Got Bewst?
*grabs popcorn*
Old Jul 18, 2012 | 11:53 AM
Please note Aaron WE DID NOT USE THE BUSHING IN THE PICTURE IN 2006,7,8; in did use it in 2009 for OTT. Not in 2011 and 2012. We detail in our web site the difference in class A and class B inserts.
NON voided bushings will fail the same way eventually of they are made cheaply. The Bilstein inserts that Ott use are for a V dub.
Old Jul 18, 2012 | 11:56 AM
Okay, we will speak fair on this, as we hope you will John in return
So what you are stating is there are 2 diffent quality of voided bushings used?
Over all a voided bushing in rubber is not a good choice, as to why non-voided bushings are being used by 2 vendors now (ZZP and Powell)
Old Jul 18, 2012 | 11:58 AM
OUr all steel mounts are 110 stage 1. I dont use stage 2 myself. If folks want to send their broken insert mounts to be, they pay freight both ways, I suppose I can replace the bushing free of charge, with a superior one, which will require new spacers which I can supply.
Hopefully this will not start a landslide, as this will cost me about 60 dollars to fix . The other thing is, frieght both ways will make it marginal to do for the OP. Of course, I can sell you a new bushing and you can put it in, but it still requires a different set of spacers.
