p0300 car sounds like a subie
So driving back to my buds place my car started ti sound like a subie. And the cel started flashing. . P0300 code. It might be wet coils. Hoping its juat plugs. It was raining today too.
Please help me fix my car
lol i had a car that was fine all year round, if the temp went above 95 degrees, after 10 minutes of driving it would start sputtering and get progressively worse until it would barely accelerate from how bad the misfires were. Replaced the ignition coil, problem dissappeared. lol
Pulled it all apart. Found #4 coil exploded, spark plug lossened and stripped the threads in the head, and now s*** hit the fan becayse I haven't touched it since the dealer did. Anyone a kind of repair fir this?
Hah, as soon as I saw the title. I'm like, "Here's another one.." That happened to me and DSmastery up there.
You're gonna need a helicoil, timesert, or new head. Proposed cause of this is a cross threaded plug.
DS and I have ours fixed with a helicoil. I will say the car sounds sweet running on 3 cylinders.
This, you have a good torque wrench and mechanical know how pull the head and insert the helicoil or a new head, if you don't give to the dealer or your mechanic to install the helicoil or a new head
village idiot
Mine sounds like a Subaru sometimes right now. Check engine light is always on and flashes occasionally. Started a few days ago. Mods are intake, exhaust, charge pipe, intercooler and tune. Mods haven't changed in about a year. Mileage is 42K.
I pulled the codes. P0300, P0301, P0302, P0303 and P0304. Pulled the plugs. Everything looked good except plug 1. It was a bit more fouled and there was oil on the threads. It was a little loose. So I put in new OEM plugs and cleared the codes. The CEL came on again. It flashes only at low speeds in first or second. Highway driving is fine. It's just when driving through neighborhoods or taking off that it has a problem.
I guess I'll clean the MAF and change the oil. It's due and is showing the oil at 59%. If that doesn't work, I'll change the coil packs. If that doesn't work, I'll put a new head and gaskets on there.
Lemme know if anyone has any other suggestions.
FML. LOL.
FML. LOL.
yea the oil on the plug is the cause, got a bad seal / gasket.
car is just misfiring badly at low rpms, the flashing cel. i mean u have random misfires and specific ones which isnt good.
i havent see too many lnfs blowing threads, so as long as the plugs thread your good. but the sooner the leak gets fixed the better
village idiot
Since the car is at 42K miles and it needs an oil change, I figure I'll just go ahead and:
- seafoam
- new oil
- new plugs
- new evap purge solenoid
- new coil packs
- new valve cover gasket
Then clear the CELs and hope that nothing pops up for a while. If it keeps doing it.... well I'll be pissed.
Took the balt for a fishing trip 2 hrs from home. On the way back I beat on her a little, engine light came on not flashing though. P0300 random misfire so I monitored it and seen 2&3 misfiring. Swapped cools to opposite cylinders and still2&3.. took plugs out and they were burning rich not as clean as 1&4. Not sure what to check next
Getaway_Driver
40
09-10-2015 09:11 AM
Getaway_Driver
09-08-2015 09:41 AM
