Perfect Headlight Research
Hello guys!
I am researching what is the best setup for headlight bulbs. I did the H7 conversion but ballast keep blowing up on me so I want a more reliable solution. I was looking at the LED options because I assume is less heat for the headlight and my zone is tropical (temps range from 65f to 98f). I have the aftermarket projector headlights and I want something that does not blind other drivers on the road while providing good illumination.
thank you in advance
What ballasts are you running?
Given the tropical location I would make sure to run a potted ballast (circuit board sealed from moisture/water), as I'm sure all the moisture and salt in the air is getting in there and shorting things out. Here is a set https://www.theretrofitsource.com/am...moto-xb35.html
Now sure what type of connection your bulb is, but theretrofitsource carries a lot of stuff and they will call out if the ballasts are potted.
