Performance upgrade questions
Old Aug 16, 2008 | 01:51 AM
joemama's Avatar
So i know you can get the basic upgrades, Stage 2, cold air intake, exhaust, nitrous.
What else can i do?
I have a 05 SS 2.0 and am looking for what else i can do.. From what i take with those mods i can get about 300 hp(nitrous can give more or less depending on how safe i want to be.). What else can i buy? i want to get about 400 hp hopefully and dont want to use a 150 shot to get there....
Help me please...
I also know people post this stuff all the time and people say to use the search but i did for like 2 hours straight and couldnt find anything but the basics... so now i ask for help.
Old Aug 16, 2008 | 01:52 AM
D4u2s0t's Avatar
ditch the stock blower. pretty much the only way.
Old Aug 16, 2008 | 01:58 AM
joemama's Avatar
who sells an after market one? and how much am i looking at? and if i ditch it why dont i just turbo it?
Old Aug 16, 2008 | 02:00 AM
D4u2s0t's Avatar
bingo.
if you can do the work, and can piece together a turbo kit, you can do it for a few grand.
Old Aug 16, 2008 | 02:01 AM
wardzach2007's Avatar
nitrous? hmmm?...
Old Aug 16, 2008 | 02:03 AM
OriGinaL Condo's Avatar
Best way as of right now is to go turbo. Check out hahn's website
Old Aug 16, 2008 | 02:05 AM
ItalianJoe1's Avatar
Also plan on a slight motor build if you want over 400whp reliably. Stock pistons won't last forever up there.
Old Aug 16, 2008 | 02:11 AM
joemama's Avatar
well they are forged so they should do 400hp for awhile...
I know what you mean tho and i just wanted to know what all i could do and basically the only other thing is turbo... is there kits out there?
Old Aug 16, 2008 | 02:16 AM
Stock pistons are NOT forged.
Old Aug 16, 2008 | 02:19 AM
joemama's Avatar
thats what i have seen on the web...
is stock intercooler better than an air to air?
Old Aug 16, 2008 | 09:33 AM
Kibosh3's Avatar
they are not forged...
Old Aug 17, 2008 | 12:06 PM
EatonTVS07's Avatar
the rods are forged, check it out here https://www.cobaltss.net/forums/general-cobalt-68/info-all-balts-engine-internals-tranny-118908/
and are you asking if air to air is better then air to water?
Old Aug 17, 2008 | 12:18 PM
Tazmanian_Dvl's Avatar
well I hope you don't like your motor too much because the nitrous is gonna make it go boom
Old Aug 19, 2008 | 05:33 PM
joemama's Avatar
im asking if an after market air to air is better than the stock air to water
Old Aug 19, 2008 | 05:41 PM
theneelster's Avatar
I agree...should probably go turbo...hell that's what chevy decided. Besides, if you go aftermarket you can get a loud ass blow off valve.
The deal is that with a turbo it uses exhaust gas to spin a turbine that's attached to the compressor wheel and the gas makes the turbo really hot hence the air that the compressor pulls in gets hot from the heat from the turbo. The compressor sends the air to the throttle but usually goes through some type of intercooler. Usually liquid cooled intercoolers CAN cool better but air to air are generally cheaper and bigger so the cooling differences may be small. As well with an a/a no lines or chances of fluid leaks. Is this right or wrong?
Last edited by theneelster; Aug 19, 2008 at 05:41 PM. Reason: Automerged Doublepost
Old Aug 19, 2008 | 06:30 PM
joemama's Avatar
I know air to water is best. BUt what i want to know is that the stock air to water is it any better than an air to air?
because usually stock stuff isnt the best
Old Aug 19, 2008 | 07:29 PM
TurboTechRacing's Avatar
What else can i do?
Help me please...
A header kit, and solid engine mounts mounts....
You might want to also lower it and get a sway bar on there...
Old Aug 19, 2008 | 07:36 PM
Greased's Avatar
why? if you use it inccorectly it will. Your engine will also go boom if you pulley down and dont tune accordingly. nitrous is perfectly fine if used within certain parameters. Cbodnar has done it if you dont believe me, ask him.
Old Aug 19, 2008 | 07:39 PM
StageII07's Avatar
You wouldnt really need to go turbo to get 400whp outta it right?..u can get a better supercharger and stuff..that what im sticking wtih just a supercharger..hopefully get 300 -350 outta my car..just get new exaust and heads cams and what not..pistons..what not ..mounts..tranny?..
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
dieGone
Oct 1, 2015 06:27 PM
