Is this possible, or out of the question?
Old Jan 17, 2006 | 12:43 AM
x8xViperx6x's Avatar
Ok, my cobalt is a 06 base LS (in other words, no power windows/locks). I want to add power, but I have no idea where to look, or start.. is this even possible? How much would this cost? Any help would be appreciated, thanks.
Old Jan 17, 2006 | 12:48 AM
Cobalt_Supercharged's Avatar
I know that you can get actuators for the door locks. They use them with car alarms, but not too sure on the windows.
Might see if you can scavange some parts from a junk yard. All the wiring should be there I think. Don't hold me to it though.
Old Jan 17, 2006 | 12:50 AM
alleycat58's Avatar
Anything is possible with enough time and money. If it's not possible for you to do, then just think of it this way - you're saving weight by not having power window motors and lock mechanisms...
Old Jan 17, 2006 | 12:54 AM
True, but it would just be that much nicer to have.. I think im still going to look in to it.
Old Jan 17, 2006 | 12:55 AM
You could always trade the 2.2 for a 2.0, they come stock with power.
Old Jan 17, 2006 | 12:57 AM
I wish I could afford it!!
Old Jan 17, 2006 | 08:26 AM
wolfwood390's Avatar
yea you can get power stuff, it will take a decent amount of time and cash, my dad had a 1932 ford coupe, and put power windows and locks in it, but he also has his own auto body shop and a lot of knowledge so he knows what he is doing.. The price would vary from what shop did it for you because of labor rates and storage, if its more then 1 days work.
Old Jan 17, 2006 | 08:32 AM
TimDang's Avatar
Best bet would look around at the local junkyards. Just get the entire door panel and everything, just have to color match. I picked up the whole rear suspension off a SS/SC for $400, springs hubs everything. The supercharger was gone the minute it was towed in lol. Just gotta look, gems to be found. You try and do it through GM and i'll be expensive. Some companies (Autoloc) make universal stuff, but you'll have to do custom switches and the like.
Old Jan 17, 2006 | 08:51 AM
badg1rl's Avatar
my bf did a conversion on a ford probe. with parts (which he had to find)and all the labor for install i think it was about 500.
Old Jan 17, 2006 | 03:54 PM
Roadrunner's Avatar
rummage a wrecker to start, then talk to gm.
but i say install it yourself, if anything goes wrong in the future (and im sure it eventually will) you will know how to repair it. also check out ebay, sometimes they have some used parts too.
Old Jan 17, 2006 | 04:59 PM
bluegt2k's Avatar
if you do a search on google for "autoloc", they make pretty good kits for power door locks and windows
Old Jan 17, 2006 | 06:42 PM
Ok, looks like im going to go to the junkyard!
Old Jan 17, 2006 | 06:58 PM
Brian MP5T's Avatar
www.car-parts.com
Old Jan 17, 2006 | 07:02 PM
T Dawg's Avatar
in a base the fuses aren't "wired" in the fuse box that normally go to power locks, windows, sunroof, etc. The door wiring harness also only contains speaker wires, so yes it will be a decent project. I'm in the same boat as you, but with 4 doors to contend with. I don't want the windows, just the locks and alarm.
Old Jan 17, 2006 | 07:26 PM
Hey if you acctually get around to starting that.. update me if you find anything vital. Thanks.
Old Jan 17, 2006 | 09:23 PM
T Dawg's Avatar
It'll be a while, when I get my tax money hopefully. I always do my own work because I'm.....thrifty and love to learn new tricks.
Old Jan 17, 2006 | 09:52 PM
VaMP's Avatar
Would of been cheaper to get it from the factory....
Old Jan 17, 2006 | 10:05 PM
Brian MP5T's Avatar
No It would be cheaper to get it from a wrecker.
www.car-parts.com
Old Jan 17, 2006 | 10:24 PM
victoryredss's Avatar
If you want I can install both windows and locks, I used to install them all the time as an "installer" at the best buy off bell/grand, just pm me if you are still interested!
Old Jan 18, 2006 | 02:40 AM
Sempher55's Avatar
My 03 silverado had the crank wondows.... the dealership did it for me for close to 600$ not bad... but still...
Old Jan 18, 2006 | 04:29 PM
freakaccident's Avatar
The locks would be easy. Just a solenoid with a rod that clamps to the existing rod coming out of the latch. Solenoid mounts with a simple bracket. I installed a set on a Honda Civic. It only took a few hours including wiring. We didn't setup a remote setup though. I would guess most alarms just have outputs to trigger the solenoid.
The crank windows would be tough without a kit.
Old Jan 18, 2006 | 04:34 PM
Brian MP5T's Avatar
Why not just get the **** that GM made? I mean, ****, they designed it to work with this exact car... NO BRAINER.
Old Jan 18, 2006 | 05:48 PM
because the dealership will rape you, i can do a name brand remote start with actuators and power windows for about $600.00, not bad seeing that best buy charges 450.00 for just the alarm installed
Old Jan 18, 2006 | 07:57 PM
Ditto. Probably 1500 worth of parts if you bought "complete" used doors.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
