Potentially something serious?
Old Nov 14, 2006 | 07:49 PM
blownssdel's Avatar
i dont know everything about these cars yet and i think there may be a problem with my 2.0. it seems as if something is loose when i get in and out of my car and the e-brake is pullled. i've done this over and over again and cannot figure out what it is. even when i just push on the car to make it rock the sound will make a "clank". it sounds like something in the rear as if maybe a hanger or something is missing, but when i take the e-brake off it seems to go away. any suggestions? sorry if its a repost, although i did search through threads for a while. Thanks in advance for any help!
Old Nov 14, 2006 | 07:52 PM
martinsmu's Avatar
I really dont know man, did u chek if your handbrake work properly? Nothing disconnected on that part??
Old Nov 14, 2006 | 07:54 PM
blownssdel's Avatar
it seems to work fine. i park on a hill most times. also i guess i should mention this doesnt happen all the time. just notice it sometimes. but after i start the car up and then try to rock it, the noise is nowhere to be found
Old Nov 14, 2006 | 07:58 PM
kissmySS's Avatar
mine does it too... I believe its just the noise of the actual brake as it is locked... as you/car or the tire rock back and forth you will here it hit its "stop" point
Old Nov 14, 2006 | 08:02 PM
blownssdel's Avatar
thats what i kinda thought, but wanted to know if anyone had any other experiences with it. cause it doesnt happen everytime and doesnt seem to affect my car when running or driving.
Old Nov 14, 2006 | 08:04 PM
martinsmu's Avatar
oohhh i know what it is. Well could be. If you dont pull on the Ebrake hard enough, when i sit in it, or get out, the weight difference makes the brakes make a weird noise. I had the same prob when my car was new.
Try pulling ure Ebrake hard (well not hard that u break something) but pull it firmly!
Old Nov 14, 2006 | 08:06 PM
blownssdel's Avatar
could be it. what do you exactly call new. my car has just over 5k on it and i use the ebrake obviously all the time. still could do it? thanks for the help by the way
DarrenGC
Forced Induction
Jan 2, 2016 09:10 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
dennis69
Sep 28, 2015 02:16 PM
