Powell Front Trans Mount
Old Mar 23, 2014 | 02:13 PM
Joe09SS's Avatar
Just a quick question about the mount.
When I received my mount, they put in 2 extra spacers. I thought the triangle space was for the rear mount and I have no idea about the other cylinder spacer. Anyone have any info on this, maybe John himself? ;P thanks in advanced.
Old Mar 23, 2014 | 02:15 PM
taintedred07's Avatar
Correct the triangular spacer goes underneath the rear stock mount. The 2 circular spacers go on either side of the Powell front mount.
Old Mar 23, 2014 | 02:18 PM
Joe09SS's Avatar
I'm only upgrading the front mount, so why did they give the triangle one? Am I supposed to put that in along with the stock LNF rear mount?
And will I need that cylinder spacer? I think I only got one, idk if you implied there should be 2 or not.
Old Mar 23, 2014 | 02:29 PM
Omiotek's Avatar
you need to put the rear mount space in to aid with the rotation of the motor and the 1 front piece goes inbetween the subframe mount and his mount. you will see right away where it goes when you bolt up the mount to the trans. it only goes in one spot.
Old Mar 23, 2014 | 02:41 PM
Joe09SS's Avatar
Alright. The triangle bolts to those 3 bolts off the frame?
Old Mar 25, 2014 | 02:43 AM
Lesley Stern's Avatar
I searched and searched looking for info on these mounts... What are the owner's opinions on them? I am looking for a rotated mount and heard these are the best. What material is the insert? I am looking for a stock feeling (low increase in NVH) and want the benefits of the rotatated mounts.
Old Mar 25, 2014 | 07:02 AM
Piston3's Avatar
My brief experience before my motor grenaded was excellent. No vibration at all. Tried to rock the motor in the engine bay and it wouldn't budge an inch. Stage 1 is perfect for a DD. Can't wait to test the real reason for buying them soon lol.
Old Mar 25, 2014 | 07:03 AM
Piston3's Avatar
It sits inside the mount. You'll see. It only fits one way in one spot.
Old Mar 25, 2014 | 09:36 AM
Joe09SS's Avatar
If you say so :P
Old Mar 25, 2014 | 09:41 AM
colodude18's Avatar
Here's the how-to I did when I installed mine:
5280cobalts.com Forums-viewtopic-How to: Install rotated engine/trans mounts
Old Mar 25, 2014 | 10:35 AM
Joe09SS's Avatar
Thanks. Little hard to see the rear spacer but I'll figure it out. That's the only part I'm uncertain about lol
Old Mar 26, 2014 | 10:50 AM
ChriSS09's Avatar
John should have emailed you a great how to on it with every minor detail when you purchased it from him. I've had mine for just over a month now and they are great. No vibes at all but no wheel hop either. Yes the circular spacer goes on the driver side of the front tranny mount and the keyhole spacer goes under the rear mount.
Old Mar 26, 2014 | 02:41 PM
Omiotek's Avatar
The triangle part goes between the subfranr and rear mount. Then set the mount back on it. It only fits and works one way
Old Mar 26, 2014 | 04:48 PM
Joe09SS's Avatar
I wish he did email me. But no biggie.
If you say so, with my luck I'd screw it up Lol.
Old Mar 29, 2014 | 03:08 PM
Piston3's Avatar
Old Mar 29, 2014 | 06:54 PM
Powell Race Parts's Avatar
I am not understanding this. While I try to send "how to " instructions with every purchase, I may well have screwed up and not done so. If you have an F23 2.2 or 2.4 the front mount has two spacers and is different. I fyou have an 04 redline the mount is different with a single spacer. If you have an 05-10 SS s/c or turbo there is one spacer. All use a triangular rear spacer.
Please email me john@powellraceparts.com for a detailed "how to" I am kinda at a loss to figure out why you would not email me to get the "how to". My apologies for not sending it, I need your email to do so. cheers
Old Mar 29, 2014 | 06:56 PM
Not if it is the latest generation all steel mounts... just one spacer at the front.
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
n20saturn
Sep 30, 2015 12:26 AM
