Pretty pissed
Old Oct 7, 2013 | 01:34 AM
Unique Crysis's Avatar
Originally Posted by SpencLangfitt
what really sucks is I got this car 8 months ago, broke it the second day, then did all this work and I got to drive it for 1800 miles and boom, this **** happens too me. #becauseracecar
Man that sucks, that's just bad luck, I would just put it back to stock especially since its your dd
Old Oct 7, 2013 | 01:40 AM
andrewcarr1993's Avatar
Am I the only one that reads that and thinks he should be able to get his own car back so he can work on this one?
SpencLangfitt's Avatar
I can't really now seeing as I broke the block too..
I'm thinking of just doing a lnf swap, and parting out my lsj since I still have a lot of good parts on it. I guess we will just see when I go back to my shop tomorrow and take a better look at it all now that I've had time to cool down a little bit
Old Oct 7, 2013 | 01:43 AM
in any other case I would take it back but the friend I lent it too is just getting back in their feet aswell as getting their life back together. So for the next few days I'll be driving the built Camaro till I find something out..
Old Oct 7, 2013 | 02:28 AM
southal cobalt's Avatar
what pulley diameter are you running? who tuned it? does the ic pump work?
must be on stock exhaust if you can see the boost gauge max out.
Old Oct 7, 2013 | 07:15 AM
sLAsh's Avatar
Just see Mongo for a short block and start over with more realistic goals this time. If you want to do 20+ PSI buy a TVS if you want to stay SC or go to turbo. Trying to push that much on the little M62 is just asking for it to blow up. Fine if you just use it on the weekends but not a good idea for a DD.
Old Oct 7, 2013 | 08:21 AM
user 72239's Avatar
23 psi is not smart on the M62. No wonder the sleeve gave.
Turbo it or TVS It
Old Oct 7, 2013 | 08:22 AM
Avalanche687's Avatar
Turbo it or TVS It
This
Old Oct 7, 2013 | 08:29 AM
yup when i saw 23 psi i was like damn that engine is gonna be pulling timing on an m62 especially if you had a ported head and everything still seeing numbers that high. what pulley was that on a 2.6? 2.5 with a machined snout?
Old Oct 7, 2013 | 09:56 AM
LNFTX's Avatar
Turbo it or TVS It
This x2456887533
And get a new tuner/builder
If you were looking to not push that motor to the breaking point 23psi on the m62 was not a good place to start
Old Oct 7, 2013 | 11:15 AM
  #36
I'm thinking about just swapping it with a turbo'd motor, anyone have any experience on how much work it is to convert a sc to a tc?
Old Oct 7, 2013 | 11:22 AM
  #37
user 72239's Avatar
not worth it, some dude did it on here and it cost him more than just buying a TC outright. they may look similar but you need a donor car, wiring from front to back etc.
The LSJ is a good motor, I would not want to swamp an LNF into an LSJ car personally.
Old Oct 7, 2013 | 11:58 AM
  #38
as stated, it would be hard to do and expenseive. on top of that, you would have a harder time tuning for e85 if you wanted it in an lnf, you wouldnt have the ability to change to "much" larger injectors as can be done with the lsj since the lnf is di, and tuning an lsj isnt hard. the lsj can handle good power on a stock motor. but there is no reason to boost the crap out of an m62.
what supporting mods do you have now? are you on a 2.5" pulley, stock head, and stock exhaust. thats the only way i could see you making 20+ psi. but i dont know how you are measuring that without an interceptor or other boost gauge, as the stock gauge only shows up to 20 psi
Old Oct 7, 2013 | 12:27 PM
  #39
My motor has a .020 over bore, it's forged, ported m62, zzp 2.7 pulley set & tensioner, stage 3 ky clutch, 80lb injectors, zzp long tubes, 3.25 all the way back, 3 in intake, solid mounts.
I think I may just part out the whole car cause it has low miles and good parts.
Not sure though..
Old Oct 7, 2013 | 12:41 PM
  #40
JapEatr's Avatar
South Central *********
Hahaha the people replying to technical posts dont need to be replying to technical posts.
this
Old Oct 7, 2013 | 01:58 PM
  #41
ebristol's Avatar
The weak point of the stock LSJ engine is the pistons. When you replace the pistons with forged components the new weak spot is the sleeves.
It is extremely common for people to break sleeves with forged pistons. It's happens hundreds of times on the LSJ.
You should have gotten new sleeves from Mr B and had the sleeves custom honed to fit the new pistons.
Old Oct 7, 2013 | 02:50 PM
  #42
SalvageBaltSS's Avatar
So let me get this straight , you rebuilt you motor, with all the good stuff, then put 23 psi on a rebuilt motor, with out braking in the motor slowly 1,800 miles is not enough for a rebuilt motor to brake in, with 23 psi of boost , you should have dialed back the power, and drive it soft, till the motor had more miles.
Old Oct 7, 2013 | 02:59 PM
  #43
Gelladuga69's Avatar
How many people here understand why the 23psi wasn't good on M62?
I just assumed 1500 of those 1800 were break in. Then the last 300 were hard miles and blew it up.
Old Oct 7, 2013 | 03:06 PM
  #44
user 72239's Avatar
MOre psi = more boost at all times right?
  #45
574's Avatar
574
Not 100% true. Boost and heat seats rings
Old Oct 7, 2013 | 03:09 PM
  #46
MOre psi = more boost=all the power at all times right?
Fixed
Old Oct 7, 2013 | 03:10 PM
  #47
MoRe bO0st iS pow3R rite guys
Boost pressure means nothing lol
Last edited by Slowbalt2000; Oct 7, 2013 at 03:10 PM. Reason: Automerged Doublepost
Old Oct 7, 2013 | 03:12 PM
  #48
user 72239's Avatar
Originally Posted by ECaulk
Fixed
TIs what I meant to type, /fail
Old Oct 7, 2013 | 03:13 PM
  #49
Sox-Fan's Avatar
Got Brakes?
boost gets you laid. moar boost gets you laid moar.
I'm wondering why people are telling him to turbo it. lotta help that's going to do that broken block now.
OP are you going to build up again or toss a runner in there and unload it?
Old Oct 7, 2013 | 10:07 PM
  #50
Sl0wbaltSS's Avatar
Okay what the hell is a front vs rear mount turbo.
Maximum LAG.
