Pretty pissed
Old Oct 7, 2013 | 11:20 PM
  #51
nhanson's Avatar
Originally Posted by SpencLangfitt
My motor has a .020 over bore, it's forged, ported m62, zzp 2.7 pulley set & tensioner, stage 3 ky clutch, 80lb injectors, zzp long tubes, 3.25 all the way back, 3 in intake, solid mounts.
I think I may just part out the whole car cause it has low miles and good parts.
Not sure though..
You werent seeing 20+ PSI on a 2.7 pulley unless your cat was clogged (if you even have one)
Old Oct 8, 2013 | 12:10 AM
  #52
SpencLangfitt's Avatar
I was, and I don't have a cat.
But I was running 20+ and there's no doubt about that.
Old Oct 8, 2013 | 06:00 PM
  #53
m33pm33p's Avatar
You wanna go big boy power
Better have a big boy budget
Specially on a fwd car not designed for straight line speed
Old Oct 8, 2013 | 06:15 PM
  #54
Tomtwtwtw's Avatar
There's no way a 2.7" on an M62 is going to make 23lb unless there is a restriction somewhere else. It might make 18 psi on a completely stock engine, and that's only going to go down as you improve exhaust, head, etc. Did someone cram potatoes up your exhaust pipe?
Old Oct 8, 2013 | 06:22 PM
  #55
Originally Posted by m33pm33p
You wanna go big boy power Better have a big boy budget Specially on a fwd car not designed for straight line speed
I've got the budget, I obviously picked the wrong car. So the cobalt will get parted out or fixed and sold. Then I'll just wait a few months and go pick up a stock supra and go from there
Old Oct 8, 2013 | 09:30 PM
  #56
southal cobalt's Avatar
this thread
Old Oct 9, 2013 | 06:34 AM
  #57
Nfamous60's Avatar
Well that says it!!
Old Oct 11, 2013 | 10:07 PM
  #58
IonNinja's Avatar
how in the hell do you make 23psi on a 2.7" pulley?
Old Oct 11, 2013 | 10:23 PM
  #59
andrewcarr1993's Avatar
You don't
If he really had the money he wouldn't be running a M62 still either.
Old Oct 11, 2013 | 10:37 PM
  #60
Gr8Bndimi's Avatar
Did I hear part out?
Old Oct 12, 2013 | 10:45 AM
  #61
Zooomer's Avatar
Supporting Vendor
There is absolutely no point in replacing rods and pistons and keeping a stock LSJ or LNF block. It's going to fail.
You need to swap to a gen 3 block when doing the forged internals. In fact a stock gen 3 block with stock rods and pistons is stronger then an LSJ or LNF block with forged pistons and rods.
ZZPerformance - Gen 3 LNF/LDK Short Block #ZZ-LDKSB
http://shop.zzperformance.com/store/...ort-Block.aspx
Old Oct 12, 2013 | 11:06 AM
  #62
What gen 3 block replaced the LAP?
Old Oct 12, 2013 | 11:09 AM
  #63
Blocks are pretty similar. Pretty sure you just use a different crank/internals/head.
Old Oct 12, 2013 | 08:36 PM
  #64
2010CobaltLTfan's Avatar
Could you seriously swap the gen 3 block for the 2.2 Lap
Old Oct 16, 2013 | 11:59 PM
  #65
Yes that's what 2.4's and 2.0's are starting to do.
Old Oct 17, 2013 | 10:23 AM
  #66
Shortbus's Avatar
Over night parts from Japan.
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
