Problems with new CCFL Headlights
Old Nov 11, 2010 | 11:15 AM
ZZRider618's Avatar
Lightbulb Problems with new CCFL Headlights
I just installed my new CCFL headlights and am having problems with the Outter Rings (the projector rings). the inside rings light up fine but the outter ones are real dim and eventually start to brighten up but then start to flicker. the driver side seemed to do it when u shook the inverter box so i think it may be a loose wire, but on both headlights? anybody else ever have this problem? both rings are going to the same power source.
Old Nov 11, 2010 | 11:21 AM
TommyP's Avatar
AWD > FWD
I would say either bad inverter (not surprising) or a bad ground.
Old Nov 11, 2010 | 02:53 PM
Gixxercobaltdriver's Avatar
Yup loose connection somewhere. best thing to do is take the connections out and redo them on the flickering ones... BEST thing to do rather than try to trouble shoot where, unless you sorta know where you might have had the problem at... did you do a toggle switch or off the running lights?
Old Nov 11, 2010 | 04:54 PM
ZZRider618's Avatar
well i guess they didnt have enough power to ignite, once i started the car they came on and stayed on. i'll see how they work tonight or if they start flickering again
Old Nov 15, 2010 | 12:59 PM
Kyle_06_SS's Avatar
When it's really cold out, the outer rings on my CCFL headlights don't come on until I start the car. I just assumed with was the nature of the CCFL having to "warm up."
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
