? Question about the Boost gauge ?
Old Jun 12, 2005 | 08:48 PM
codyss's Avatar
Is there anyway to zero the gauge or set it?
With only the key on my gauge sits below zero and at full boost it misses 12psi by the amout it is below zero.
Old Jun 12, 2005 | 09:10 PM
Cooked_Electron's Avatar
Well at idle it won't be a positve boost...it's in vaccum until you romp on the throttle.
As for not hitting 12psi...i can't say why that'd be. Mine's in kPa....stupid metric system....and I get a tad over 80 kpa...
81kpa x 0.14504 psi/kpa = 11.7 psi - that's close enough for me.
Old Jun 12, 2005 | 10:15 PM
PygmySurfer's Avatar
Just curious, how long have you had your car? Best I seem to be able to get is 60 kpa..
Old Jun 12, 2005 | 10:36 PM
wesmanw02's Avatar
My question to you is how long have you had your car??
Because if your car is still in the break-in period, the computer won't allow the engine to see full boost. From what I've heard, it is limited to about 10 PSI.
After the break in period, you should be able to hit 12 pretty easily
Old Jun 12, 2005 | 11:24 PM
I've got about 3000km's on mine now.
I wonder if geographical elevation has anything to do with this too...?
Old Jun 13, 2005 | 09:33 AM
codyss's Avatar
Im talking about when I only have the key on and the and the needle is suposed to zero.
Old Jun 13, 2005 | 09:59 AM
smartmts123's Avatar
mine quickly snaps to zero when I hit the starter - then it goes into vacuum... as for the 12 psi, i seem to be able to hit it whenever i want to (and i've only got 1400 mi)
Old Jun 13, 2005 | 12:10 PM
Chevy4Life85's Avatar
Soundss like we are having some BOOST issues, just smoke start doing LSD the G85 type and all fo your problems will go away.....
Seriously though if its broken in just bring it into the dealer and say you want your 12psi
Old Jun 13, 2005 | 12:17 PM
RACIN_RANDY's Avatar
Boost Gage
Check Your Manual, At Sea Level The Gage Will Read Zero, If Above, Or Below Sea Lavel, It Will Read Differantley.
Old Jun 13, 2005 | 05:47 PM
About 800 miles (1300kms).
Old Jun 13, 2005 | 06:40 PM
mchat's Avatar
If the stock boost guage is the same as the SRT-4 (which I've heard it is) then it will vary from car to car. Some SRT-4 guages were off by as much as 5psi... and contrary to the excuse given in the owners manual it has nothing to do with above or below sea level.
It's just the cheapest boost guage that Autometer makes, hence quality is minimal.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
