Question: HID Install
Old Oct 7, 2009 | 12:36 AM
Testabus's Avatar
What's the best way to power a HID kit when your battery is in the trunk?
Old Oct 7, 2009 | 02:25 AM
OneSlow_SS's Avatar
they plug into ur factory harness..u dont need to go to ur battery
Old Oct 7, 2009 | 02:28 AM
Acey's Avatar
You moved your battery to the trunk?! How-to NOW!
I kid. Hook up an inline fuse to that post with the red cap over it in your fusebox if you wanna run your own wires. Try not to blow your up.
Old Oct 7, 2009 | 03:49 AM
OneSlow_SS's Avatar
in the SS the battery is in the trunk..
Old Oct 7, 2009 | 04:05 AM
steddy2112's Avatar
He was being sarcastic.
All cobalts have their batteries in the trunk
Old Oct 7, 2009 | 09:17 AM
BLK08SS/TC's Avatar
The easy way is to hook it up to your factory harness, but there are times when your HID's may not come on and you have to shut off the lights and try again. If you have any major drain on your car like a stereo system you may see the headlights dimming. It is always better to power the HID's from the battery for constant power. Even though the battery is in the trunk, there is the post under the hood for boosting the car that you can tap into for the power supply.
Old Oct 7, 2009 | 10:52 AM
DaBuzzard's Avatar
The easiest way if you want to run a relay harness
Old Oct 8, 2009 | 12:51 AM
Testabus's Avatar
Thanks! I'm going to give it a shot.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
