Question for LED tails
Old Dec 29, 2013 | 03:31 PM
06G85's Avatar
I need new resistors but I'm looking at other options.
Is there a fuse that I can change out to fix hyperflash? Something like this..
Car 3-pin Electronic LED 12V Flasher Relay Fix for Turn Signal Blinker Light : Amazon.com : Automotive Car 3-pin Electronic LED 12V Flasher Relay Fix for Turn Signal Blinker Light : Amazon.com : Automotive
Old Dec 29, 2013 | 03:35 PM
06G85's Avatar
Just found out the blinker rate is controlled by the BCM. Resistors are the only cure :/
Old Dec 29, 2013 | 05:18 PM
damn; i was hoping to find a magic remedy in here
Old Jan 26, 2014 | 08:45 PM
LotusRenaultF1's Avatar
If you get LEDs with the same power output as the stock bulbs you can avoid the resistors. My only problem is finding such bulbs.
Old Jan 31, 2014 | 11:09 PM
06G85's Avatar
what about "tuning" the BCM to adjust for LED bulbs?
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
