Quick Boost Question
Old Mar 22, 2007 | 08:25 PM
XM15's Avatar
Question Quick Boost Question
I was talking to a friend the other night who has an RL. I asked him how much boost he was pushing and he said "14 psi". I then asked if he had changed pulley sizes and found out that he hadn't, but that another friend had "done something else to the engine for him." So my question is, is it possible to up the boost without changing pulley sizes? Thanks.
Old Mar 22, 2007 | 08:41 PM
RaineMan's Avatar
Unless the cat is clogged or something... there's no way I know of to raise the boost without changing pullies...
does he even have a boost gauge? Non comp-pkg RLs don't even have gauges.
Old Mar 22, 2007 | 08:45 PM
Doc's Avatar
Doc
My bet is your friend isn't reading the boost gauge correctly. You'll notice the stock gauge has the numbers 10 and 15 then 3 lines in between. The lines represent 11.25, 12.5 and 13.75....I guess its close...but no cigar
Old Mar 22, 2007 | 09:02 PM
XM15's Avatar
I'm not sure if he has a boost gauge. All I know is that his RL is an '04. I should remember this because I did ride in his car once. Of course, I was more concerned with the blue lights behind us...
Old Mar 23, 2007 | 06:33 PM
XM15's Avatar
Anybody else have an idea?
Old Mar 26, 2007 | 06:14 PM
XM15's Avatar
Well, I found out what they did. Apparently they "disconnected the signal line that opens the bypass at high rpm". Thats how he's making several extra pounds of boost. Could this have some negative effect on his engine over time?
Old Mar 26, 2007 | 06:16 PM
ecotecon18s's Avatar
...yeesssssssssssssss.... CEL FTW!!!
Old Mar 26, 2007 | 06:18 PM
charged_sunfire's Avatar
of course you can see more boost without changing pulleys, just port out the blower
Old Mar 26, 2007 | 06:37 PM
thought's Avatar
CAI
porting(SC or TB, which isn't feesable for us)
pully
tune.
Those are the only things I can think of
Old Mar 26, 2007 | 08:52 PM
Doc's Avatar
Doc
thats called the boost bypass mod...it works.
Old Mar 26, 2007 | 08:56 PM
AROON02's Avatar
Porting The Blower Is Our Boost Bypass Mod, I Thought It Was More Than That, Idk Which Is Why Im Aksing
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
