quick question
Old 01-22-2009, 07:39 PM
mike25's Avatar
quick question
would a good weld on bung with a plug be enough to stop any leaks from happening on the oil pan wall above the drain plug?
Old 01-22-2009, 07:42 PM
PRND3L's Avatar
as long as its a good weld, would be like having a second oil drain plug, shouldnt leak.
Old 01-22-2009, 07:46 PM
mike25's Avatar
would the reason my tapped plug in the oil pan is leaking be because the wall is too thin?
also should i go with a male or female style weld on bung?
Old 01-22-2009, 07:59 PM
PRND3L's Avatar
i take it you have a threaded one in there already and its leaking, id remove it and put some/replace the teflon tape thats on it, if that doesnt fix it, then id have one welded on, those oil pans are thick, that shouldnt be an issue.
Old 01-22-2009, 08:08 PM
mike25's Avatar
yea i put thread tape on it and it lasted a little while but its leaking again.
which bung style would be better and less leak prone, a male or female style?
Old 01-23-2009, 11:45 PM
batboy's Avatar
I had a similar problem trying to stop a leak through the fitting threads of a transmission cooler. I tried the teflon tape and several things. Then, finally went to Advance bought a tube of Permatex high temperature thread sealant. That worked like a charm.
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 07:39 AM
patooyee
10-15-2015 05:11 PM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
Quick Reply: quick question
