Rear drum to disc conversion
Old Mar 7, 2018 | 07:26 PM
jdbaugh1's Avatar
I'm considering swapping LSJ brakes onto my rear drum Cobalt at some point. I want to keep the 4-lug hubs. I know the drum brake rear twisting beam doesn't accept disk brakes as is but Powell makes and adapter plate. I was wondering if maybe there was also a way to use the LSJ rear twisting beam but still keep the 4-lug setup. Anyone with experience with these your words would be appreciated.
Old Mar 7, 2018 | 07:29 PM
Jesse's Avatar
Are you the one with access to a cnc? You could easily fab a bracket and keep your existing rear beam if that were the case. I had someone fab some z06 brake bracket for my other car.
Old Mar 7, 2018 | 07:32 PM
07blackg5's Avatar
Slobodan Milošević
The 4 lug hubs bolt to the feet beam. Everything bolts up, but you have to have lsj rear rotors drilled to 4x100
Old Mar 7, 2018 | 07:45 PM
jdbaugh1's Avatar
Yeah, if it can just be made out of a piece of flat I have access to a guy with a laser table through work. Whats the best way to figure out the dimensions or are they available somewhere?
Old Mar 7, 2018 | 07:52 PM
Jesse's Avatar
I didn't plan that far ahead. You could look up the patent for the conversion kit ssbc made
Old Mar 7, 2018 | 08:51 PM
This, you can do it yourself too
Old Mar 8, 2018 | 06:36 AM
jdbaugh1's Avatar
Thanks all, good info. I pulled out the front LSJ calipers that I had bought previously though never closely inspected and of course the boot is ripped on one of the cylinders. Is it worth trying to rebuild these or just buy some store brand calipers?
Old Mar 8, 2018 | 10:45 AM
tomss's Avatar
Why do you want to keep the 4 lug setup? Do you have rims that you are attached to?
Old Mar 8, 2018 | 11:43 AM
They arent super hard to rebuild, store ones arent crazy expensive. Thats your call.
Old Mar 8, 2018 | 12:00 PM
jdbaugh1's Avatar
Yes I do and I also don't see the point in moving into a stud configuration that is more rare with less wheel options. Drilling rotors seems like a fine alternative.
Old Mar 8, 2018 | 12:43 PM
07blackg5's Avatar
Slobodan Milošević
I mean to be fair, if you are drilling rotors anyway, you can go to a 5x114.3 setup and have endless wheel options
Old Mar 8, 2018 | 04:43 PM
jdbaugh1's Avatar
Or I can stay 4X100, keep the 8 wheels I already have, and run steelies when I want to burn off cheap tires or go into sleeper mode. I'm staying 4-lug, true to the origins of my shitbox.
Old Nov 3, 2018 | 09:26 AM
pawntec's Avatar
yeah 4x100 is a lot more choices in wheels. my LS is my project and my SS/TC is my summer DD.
ECaulk
May 31, 2012 06:13 PM
midnightracer_07
Nov 11, 2011 11:46 PM
strykr
Aug 17, 2011 08:38 PM
Suaveat69
Jun 20, 2010 02:56 PM
