Recomended GAS
Old Feb 15, 2006 | 07:28 PM
BCobaltSS's Avatar
Recomended GAS
What is the fuel that everyone is using? Since it is supercharged of course 94 oct would be ideal but the prices on gas are crazy. I have been putting in 89 midgrade what does everyone else use?
Old Feb 15, 2006 | 07:30 PM
3fo893013L's Avatar
91, 93, 94, sometimes 100 (car goes nuts with that in it).
Don't put mid grade in, bad idea.
btw welcome to the site
Old Feb 15, 2006 | 07:31 PM
GSoccer24's Avatar
93 all day, i'd put in higher if i could find it around here.
i wouldn't go below 91 with forced induction
Old Feb 15, 2006 | 07:32 PM
memphisr24's Avatar
Yeah try not to put anything below 91 octane. I always put 93 in. I've never tried anything else besides 93 octane.
Old Feb 15, 2006 | 07:33 PM
p7x's Avatar
p7x
https://www.cobaltss.net/forums/show...hlight=gas+run
91 at the minimum, says it right in the manual. The highest octane I could get at a pump!
Old Feb 15, 2006 | 07:35 PM
Erod's Avatar
Moderator Alumni
Hell, there are like 10 posts on this.
Old Feb 15, 2006 | 07:37 PM
Nuclear's Avatar
sunoco 94 since new
Old Feb 15, 2006 | 07:47 PM
mcglothlindl's Avatar
10239087578965956 octane only!!
Old Feb 15, 2006 | 07:48 PM
JoeyCobalt's Avatar
You can put whatever grade gas you want in it, you just will not get the performance that the car was designed for with anything less then 91. I have read this question before, among others that always leaves me scratching my head as to why people who bought a performance car now turn around and want to cheap out on things like tires, oil changes, and yes gas. You are really going to bitch about what, $5 a tank?. If you find gas to be to expensive why not go all the way down to 87 and then you can have soccer moms in mini vans smoke you in your cool new car at the lights. Maybe you should read your manual, you know that big book that came with the car in the glovebox with all the scary big words and not enough pictures, instead of posting a well worn and STUPID question on the board for the 100th time.
Old Feb 15, 2006 | 07:49 PM
ajent's Avatar
Ever since seeing a post on one of the cobalt sites about what products to use for what, shell was picked because their premium apparently helps clean the engine or something usefull, so that's all I use.
There is a station nearby though that has "racing fuel" advertised, not sure what octane, but I think it's over $5 a gallon.
Old Feb 15, 2006 | 07:53 PM
bluechevyss05's Avatar
dont go cheap on your gas! with a 13 gallon tank, at 20 more cents a gallon that is only $2.60 for your car to run cleaner and more efficient, and get better mileage. Dont be a cheap skate on a 20,000-25,000 investment, well not really an investment since none of the new cars are lol.
Old Feb 15, 2006 | 08:06 PM
ajent's Avatar
Yeah, that's what I figured only cents difference costs only a few dollars from empty to full. So I don't feel bad putting in the best they offer.
Old Feb 15, 2006 | 09:20 PM
p7x's Avatar
p7x
used it for the poll
Old Feb 15, 2006 | 10:49 PM
stlurbanpunk's Avatar
here premium is curently 2 15 a gallon. its the lowest i've seen in a couple months.
Old Feb 15, 2006 | 11:08 PM
Pully Police's Avatar
Here is my advice:
If you have acess to premium fuel (>=91) use it. If you need to fill up and dont have acess to premium fuel, put the best you can get in the tank. You can run 87 in these cars if you need to...the engine will sense preignition and pull back on the timing advance / richen the mixture and you will lose some performance....please dont do it all the time...only if higher octane gas is not readily availible.
If you are tuned...I would say that you should run premium all the time as the extra boost and heat combined with fooling the MAF could cause problems for you...unless you have a scan gauge and can tune your MAF to allow the engine to inject a richer mixture in the event where you HAD to run 87....but...a rich mixture is a crutch and can be detrimental to your engine if not done properly.
Hope that helps!
-P
Old Feb 16, 2006 | 09:24 AM
SSBlondie's Avatar
Originally Posted by Nuclear
sunoco 94 since new
Ditto
Filled up today at an "all time low" of 90 cents whooo-hoooo!
Old Feb 16, 2006 | 09:29 AM
BLKSS's Avatar
Sunoco Ultra 94.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
