Rims stuck need help plz
Old Apr 10, 2007 | 10:05 PM
zomghax's Avatar
Sorry for posting this in the wrong section but I need max exposure and hopefully a fast reply. Trying to put my summer rims back on, but my winter rims and tires won't come off. All the nuts are off, they just ain't moving even though I'm reefing on em. I've blasted some wd40 in the centre and around all the studs and nothing. Anyone have any ideas?
Old Apr 10, 2007 | 10:09 PM
CTORANGESC's Avatar
Start one lug a couple of threads, Then kick the tire from behind
Old Apr 10, 2007 | 10:10 PM
Dustin's Avatar
Rubber mallet?
Old Apr 10, 2007 | 10:13 PM
Gamebay11's Avatar
ditto
Old Apr 10, 2007 | 10:17 PM
DoubleClutchin_ION2's Avatar
get it off the ground high enough to remove it
Old Apr 10, 2007 | 10:20 PM
ionREDLINEracer's Avatar
I'd say bust out the rubber hammer and give it a few good shots.
Old Apr 10, 2007 | 10:24 PM
Halfcent's Avatar
I'm old school
Jack the car up off the ground first.
Sorry, couldn't resist.
You can't break anything. Keep the lug nuts on loosely, and then kick the tire hard. Seriously, just beat on it.
Old Apr 10, 2007 | 10:29 PM
jaemz's Avatar
I had this happen on a back road with a flat... I loosened the bolts, lowered the jack back down and used the power steering to help remove the tire. You should only have to turn the steering wheel a bit each way before the tire becomes loose. If the back tires are stuck, hold a board of wood against the rim and hit it with a hammer.
Old Apr 10, 2007 | 10:43 PM
Grimsaviour's Avatar
Just kick the tire a few times, and if you arent afraid of getting violent you "could" hit the rim with a hammer but i doubt it will come to that. Not recomended on mag wheels btw.
or another thing you can do is put the lugs on hand tight then back them off 1/2 turn, lower the car and push it side to side, wiggleing the ass end or front it and they should crack loose. Probably just have a little rust forming in there. its pretty common.
Old Apr 10, 2007 | 10:45 PM
zomghax's Avatar
I beat the **** out of one tire with a rubber mallet, as if it were my red-headed stepchild and no go. It's too late to keep working in the parkade, someone is going to bitch. I'll have to try again tomorrow, or just take it to tire shop and ask them to break them all for me and put 'em back on. This is insane
Thanks for the suggestions, and the laughs guys
Old Apr 10, 2007 | 10:47 PM
poppagun's Avatar
is the car off the ground and start kicking the tire.
Old Apr 11, 2007 | 12:07 AM
Dont use the mallet, kick the tire. The mallet is rubber, the tire is rubber, so you arent gonna cause much impact with that mallet. you wont damage your tire kicking it. You can also hit it with your hands. trust me it works. ;-)
Old Apr 11, 2007 | 12:16 AM
zomghax's Avatar
Well I had to give up for the night and I am back home already. I'll give it another shot tomorrow after work. Thanks again for all the suggestions..
Old Apr 11, 2007 | 12:19 AM
HackAbuse's Avatar
I always kick mine, or punch it, they just need some love to come off
turbochargedss2012
Sep 20, 2023 12:17 PM
bigdeertz
Nov 17, 2016 09:41 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Iceberg
Sep 28, 2015 01:31 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
