Rotor Questions?
Old Mar 26, 2007 | 12:44 AM
silentgarth's Avatar
Rotor Questions?
What if any special tools will I need to replace my rotors?
The studs a pressed in, right? So should I buy new studs or can I use the old ones?
Anybody that has replaced theirs please help. I plan on doing this hopefully next Sunday. And I will try to take pics of the process to make a how to.
Thank you in advance for your help.
I just realized that the studs are in the hub and not the rotor. DEE DEE DEE I there was a smiley for retard I would use it
Old Mar 26, 2007 | 12:53 AM
ItalianJoe1's Avatar
They just slide on and off once you remove the caliper and bracket. No pressing of studs or anything like that.
Old Mar 26, 2007 | 12:57 AM
And I work at an auto parts store. For shame. Could somebody take me outback and hit me on the head with a tack hammer.
Old Mar 26, 2007 | 02:29 AM
Ok, but its gonna hurt.
Its a real easy job. I upgraded my front brakes, did the whole job in maybe 4 hours, and that was with cleaning and painting the calipers, brackets, etc. I'm a little nuts when it comes to details. To do a simple rotor-pad swap, should take like 45min to an hour. Easy stuff.
Old May 10, 2007 | 07:09 PM
pinoypapi198369's Avatar
any good how to's on replacing the rotors and break pads. I did help replace those on my old mustang and i wanna do this one on my own. I just wanna replace them not necessarily upgrade them
Old May 10, 2007 | 11:11 PM
Its not hard, just remove the wheels, remove the two bolts on the caliper, hang the caliper off to the side, do not let it hang by the brake line, support it with something. Remove your pads and shims. If you need to pull the rotor, take the two bolts out of the caliper mount and remove it. Rotor slides off at this point. Install new rotor, replace caliper mount. Clean and re-install shims, I always put a little grease on the areas where the pad slides on the shim, helps to make sure you don't get any squeal. You will see shiny spots on the metal from the contact, place a tiny amount of grease here. DO NOT get any grease on the rotor or pad, if you do, be sure to completly clean it with soap and water or a solvent like brake cleaner.
The trickiest part comes here, but its still not hard. You need to open up the caliper to make room for the new pad. You can do this easily with a large pair of pliers or a C-clamp. Just place an old brake pad against the caliper piston and slowly press the piston back in. On the rear, you have to rotate the piston to retract it. It can be done with a large screwdriver, but its worth it to buy a cheap universal tool availible at autozone or discount auto parts, just turn it in with a ratchet. Make sure not to use too much pressure or damage the rubber boot around the piston. Do this until the caliper slides over the new pads. Re-install the caliper, replace wheels, all done. Press down on the brake pedal SLOWLY to allow the system to take up the slack. Once you get a firm pedal, start car and go for a ride, make sure your brakes feel good before going too fast or far.
I think I covered everything, its really quite simple. Quick and painless.
Old May 10, 2007 | 11:36 PM
sweet deal thanks that sounds pretty much how we did my mustangs pads and rotors, any thing i should buy besides new rotors and pads? But better yet, my cobalt is an 05 and should still be under warranty. Are breaks covered on the 3yr/36,000mi warranty?
Old May 11, 2007 | 07:23 AM
css9450's Avatar
With ABS, aren't we supposed to open the bleeder valve on the caliper and let the fluid come out there while tightening up the C-clamp? Supposedly this keeps debris in the system from going backwards through the ABS sensors (or something). Maybe it doesn't matter with a nearly-new car.
This is my first car with ABS and I'm much more comfortable doing it the OLD way.
Old May 11, 2007 | 07:26 AM
05REDROCKET's Avatar
You should always open the brake fluid resivpr under the hood. but the only time you need to worry about anything involveing the bleeder is when yiou dissconect the caliper completely. As long as you leave the brake lines attached the brakes don't need to be blead.
Old May 11, 2007 | 08:12 AM
Right, i left that out, about opening the resivior while pressing the calipers back in. You shouldn't have a problem on a new car, since you have never added fluid, but its always a good idea just to be sure. You really don't want fluid splashing around your engine compartment or on your paint if too much pressure builds up in the resivior.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
