RWD LSJ on a 1971 TR-6
Old Nov 16, 2016 | 05:20 AM
Isaac Lewis's Avatar
has anyone else ever heard of this before?
Albert Gary's 1971 Triumph TR-6 with Chevy Ecotec LSJ Supercharged Engine
Old Nov 16, 2016 | 05:45 AM
63 Nova SS's Avatar
Originally Posted by Isaac Lewis
That is a really cool build. Looks like the lsj was made to fit in there.
Old Nov 16, 2016 | 12:16 PM
yeah. it is pretty cool. i just came across it by chance last night. im going to make one now.
Old Nov 18, 2016 | 11:32 PM
keiserX13's Avatar
Crazy project
Interesting how they moved the throttle body
Old Nov 18, 2016 | 11:53 PM
Sharkey's Avatar
i ran across this project when i was doing my porsche swap. pretty cool project.
Old Nov 19, 2016 | 06:11 AM
what do you mean by your Porsche swap? and seeing this project car makes me wonder about the tranny they used. what did they do to get it to bolt on? i doubt the bolt pattern was the same so what type of custom work...it gives me hope for seeing a RWD cobalt that has an LSJ.
Old Nov 19, 2016 | 01:26 PM
Sharkey's Avatar
i have a 2.2l l61 swapped porsche 944. it still runs the porsche torque tube and rear mounted transaxle. i have a build thread in the "other cars" section.
the transmission setup in this is simple. start out with a bellhousing from a company called quad 4 rods, it adapts the ecotec to a gm t5 from an s10 or camaro 4 or 6 cylinder. gm kept things simple and used the same clutch disc spline count on all 4 and 6 cyl cars, so the lsj clutch works just fine.
Old Nov 19, 2016 | 02:12 PM
thats crazy dude. sounds like a nice bit of work. so its a custom bell housing huh?
Old Nov 19, 2016 | 02:56 PM
Sharkey's Avatar
for the mg swap, thats an aftermarket bellhousing, off the shelf part you can order. the other option would have been to use the transmission from the solstice, it bolts up to any ecotec. it is however expensive and they are fairly long putting the shifter too far back in such a small car.
my 944 swap is an off the shelf aftermarket bellhousing from quicktime performance thats designed to bolt a t56 trans to an ecotec. from there i made a custom adapter plate to bolt it to the porsche torque tube.
