safe heat exchanger cleaning
Old Aug 10, 2006 | 10:35 AM
IMADreamer's Avatar
Well I apparently suck at the search feature so I guess I will have to bug everyone and ask. What is a safe way to clean the heat exchanger on the front of the SS/SC? I have some bugs stuck in there I want to get rid of but I don't want to bend any fins. Thanks!
Old Aug 10, 2006 | 10:52 AM
DWK5150's Avatar
That isnt the heat exchanger in the front that is actually your ac condensor. The HE is inbetween the ac condensor and the radiator. Just you a garden hose with low pressure and spray it from staight on and not at a angle and youl be fine.
Old Aug 16, 2006 | 04:49 PM
cobi's Avatar
I use an air compressor with a strong, but not to strong blow valve gets the bugs out, keeps the car dry, and best of all does not bend any cooling fins on the condensor.
Old Aug 16, 2006 | 11:46 PM
Forseti's Avatar
do it when the engine is cold...not hot...you don't want rapid cooling from a hose to damage anything...
Old Aug 16, 2006 | 11:54 PM
Rangerondubz's Avatar
i used a pressure washer
Old Aug 27, 2008 | 12:50 AM
harry2008's Avatar
A sol–gel method is used to prepare cobalt based catalysts which were obtained by mixing cobalt chloride and water glass solutions. Melting lead and cobalt Cobalt in equal quantity both metals are found in general cobalt render other metals brittle.
Harry
Indiana Alcohol Addiction Treatment
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
