Seatbelt Question/Headrest
Okay, I checked the manual and didn't see anything about this.
Is there a way to remove the headrest from my 07 Cobalt LT? Or is there a way to easily remove those seatbelt loopthings that are like grey? I'm not sure what their called.
yea, lift your head rest all the way up. then on the opposite leg as the button you will see a hole in the base. take either a real thin screwdriver and stick it in there to push the button (or you can just lift the plastic and reveal the button to push with your finger). push both sides in and slide the head rest up and it will be free.
You then need to snap the small thing metal washer type things to release the seat belt holder. once those are removed you can slide the piece right off.
here is a how to:
https://www.cobaltss.net/forums/show...ight=seat+belt
here is a how to:
Don't forget to put your headrest back on after you install the seat cover - I wouldn't recommend not using a headrest at all for anyone anytime ever. Imagine if you were in a TC and ended up getting some serious backwards whiplash?
Your neck would snap backwards - and break.
-Aleckor
-Aleckor
he isn't removing the head rest permanently, just removing it so that he can remove the seat belt holder. front head rests are a necessity... the back ones on the other hand...
https://www.cobaltss.net/forums/show...ear+head+rests
