Shakey Steering Wheel?
Old Jun 14, 2012 | 05:30 PM
Silverbalt92's Avatar
Exclamation Shakey Steering Wheel?
When I drive, my steering wheel shakes a little ridiculously. & I have no ide(a what it is from or how to fix it! :
Old Jun 14, 2012 | 05:34 PM
07LSJ's Avatar
is it all the time your driving or after certain speeds?
did you just buy the car? if so, has it been in an accident?
have you replaced your tires recently? if so, do you know if they were properly balanced?
if its when you brake, have you checked to see if your rotors are still good?
if your going to post something like this atleast include some more info.
Old Jun 14, 2012 | 05:39 PM
Well obviously im not car smart, reason why I posted this so I wouldn't know to put all if that in there..
Old Jun 14, 2012 | 05:43 PM
07LSJ's Avatar
well it could be a lot of things. try answering what you can of what i asked you.
Old Jun 14, 2012 | 05:48 PM
Projekt's Avatar
Yeah more info is needed. Could be something as small as your tires were not balanced properly
Old Jun 14, 2012 | 09:15 PM
Slobalt09's Avatar
If its speed related aim towards things that rotate (tires usually, bent wheel, axles) if the wheel shake happens during braking its usually warped rotors.) If unsure rotate ur wheels. If the problem goes to the seat of your pants that should tell you its wheel/tire related... hope this helps
Old Jun 14, 2012 | 09:16 PM
user 70823082's Avatar
Have you hit a pothole/curb/any debree recently?
Old Jun 16, 2012 | 05:11 PM
Thanks guys. All that I can tell you is that I got the car december 31st, hasnt been in an accident, same tires are still on it, so I dont know if they were properly balanced or not. It just started doing this about 2 weeks ago & it does it when I get up to 55mph or higher & it doesnt do it when I brake lol
Old Jun 16, 2012 | 05:29 PM
nolimits's Avatar
I had the same issue and it was due to half the weights falling off on one of the wheels, maybe have a tire shop check it out.That is usually free for them to check it out.
Old Jun 18, 2012 | 12:57 AM
Slobalt09's Avatar
get your tires rebalanced
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
