Shifter problems
Old Aug 8, 2009 | 07:33 AM
hailcesar75's Avatar
Shifter problems
Under my shifter there's a pin that keeps coming loose. When that happens I can't get my key out of the ignition. I know about the buuton under the steering column but it gets annoying to have to do that everytime. Also I can shift out of park without pushing on the gas pedal, or shift into reverse without pushing the pedal too. This makes it very dangerous to drive. Every time the pin comes loose I have to remove the coin tray and lift the shifter tray, stick my hand under the shifter and manually push the pin back into place
has this happened to anyone? Is there a fix to this?
Thanks
Old Aug 8, 2009 | 07:54 AM
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
Thanks
go buy a new shifter assy,that is the only way to fix this.
Old Aug 8, 2009 | 08:44 AM
Thought they might of been an easy fix. Oh well thanks
Old Aug 8, 2009 | 12:45 PM
5hizn1t's Avatar
That's a pretty common problem with the automatic cobalts/hhr's. The shifter asm should fix your problem.
Old Aug 8, 2009 | 01:37 PM
Huh???? Shifter asm?
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
