View Poll Results: ok. Which Antenna?
Agency power Universal
0%
ARK
24
77.42%
AntennaX
12.90%
mid american auto works
9.68%
Voters: 31. You may not vote on this poll
Shorty Antenna. help?
i need help. i m ordering a shorty antenna and i need help finding out which bolt size (6mm or 7mm) i dont want to get the wrong thing. i also would like to know if anyone has a good site to order it from. Thanx you guys, and i m excitted to order my first mod. (as lame as it is)
= i need help. i m ordering a shorty antenna and i need help finding out which bolt size (6mm or 7mm) i dont want to get the wrong thing. i also would like to know if anyone has a good site to order it from. Thanx you guys, and i m excitted to order my first mod. (as lame as it is)
small problem. my mom doesnt want me to cut/saw/rip any part of my car. so thats y i need to buy one. i was just going to do what you suggested but she said i couldnt. so....
Well whatever works. I like the look of the stock one, how it has that wire wrapped around it. My dad helped me do it. He said if it looks dumb its my fault lol. Good luck to whatever you get.
Last edited by LScoupeTUNER; Dec 27, 2007 at 09:44 AM. Reason: Automerged Doublepost
You have a 2005 it has a 6MM stud. Mid America motorworks has a perfect shorty available (for the corvette but fits the Cobalt perfectly) for about $20. I sent them an e-mail a month ago asking them if they could start making their shorty with a 7 MM end -- maybe if enough people send them an inquiry they would make it.
http://www.mamotorworks.com/corvette-1-308-3464.html
Or you can go to the dealer and order a new antenna for about $20-25 and cut that one down.
hey all you got to do is unscrew your antenna and it should say on top of your stud it will say six or seven but im pretty sure the 05/06 has 6 and 07 has 7 but not for sure. i also got the ark shorty antenna works good and still get good reception
what do you guys think about this? http://www.vividracing.com/catalog/a...z-p-24309.html
get some pliers and a wrap a towel around the base if you are worried about scratching it i took mine off the other day but the antenna i bought didnt fit so i had to put that junk back on.
CAREFUL HERE! We have found that corrosion or crossthreading by the factory makes it a BEAR to get the antenna off. If your antenna doesn't come off with a wrench easily DO NOT try to turn it with brute force -- you will spin the entire assy and break the pinch welds off the mount bracket. You need to secure the assy (hold it inside the trunk) before unscrewing the antenna if you're one of the unlucky ones!
ok. i added a poll
thanx!!!
Last edited by LScoupeTUNER; Dec 27, 2007 at 09:58 AM. Reason: Automerged Doublepost
good. i live in snowy ohio and i need a tough antenna.
ok ark it is then. http://www.arkspeedracing.com/01_05_...0800-0400d.htm
does this work fer sur?
Last edited by LScoupeTUNER; Dec 27, 2007 at 10:07 AM. Reason: Automerged Doublepost
