Shorty Antenna Probs For 2007
Old Aug 21, 2006 | 07:00 AM
snobird's Avatar
well antenna x makes the antenas for the cobalt and they claim the 05 06 will fit the 07. This is the one on ebay for like 14 bucks shippped. anyways to make a ong story short they dont fit th e 2007s. after u unscrew your antenna the threading on the 7 is fatter (larger) than the 06 so please be aware before buyying them from antenna x. I have sent an emal and well guess what no reply
and by the ay i have no clue why the 07;s have a bigger antennea screw thingy?
Old Aug 21, 2006 | 08:02 AM
g5mike's Avatar
Should just cut it, looks cleaner anyways
Old Aug 21, 2006 | 08:26 AM
stonny9's Avatar
BlilBT a member on here has that problem. Bought an antenna for his 06ss/sc and wanted to see what it looked like on his wife's 06 ss/na and it wouldnt fit because his was to small.
Old Aug 21, 2006 | 08:39 AM
05BlackCobaltSS's Avatar
HA HA...that sounded funny. Anyways, i've been thinking of buying a shorty....havn't gotten around to it yet.
Old Aug 21, 2006 | 09:22 AM
RaineMan's Avatar
That's what y'all get for buying cheapo antennas... my Shorty antenna fit my SS/NA perfectly... and transferred right over to my new SS/SC with no problems.
Old Sep 25, 2006 | 09:05 PM
snobird's Avatar
i know its a old post but yea anteenna x stil hasnt responsded the new and old antenna bothe fit the 06 neither fit the 07 they did refund my money and refunded ym shipping but they still havent answeered why it wont fit
Old Oct 28, 2006 | 07:50 PM
topher21's Avatar
snobird just wondering if u finally found and antenna that fit i'm getting tired of my orginal one and finally took it off, if so can you tell me where or anyone else reading where to get a shorty antenna for a 2007 ss thanks!
Also I emailed antenna x and they say it fits but from what i've been reading everyone says it doesn't? just dont want to waste time or money-
Old Oct 28, 2006 | 07:55 PM
BlilBT's Avatar
Its Not the case>> The newer cars have a Fatter Screw they are not the same & I dont Buy Cheap! My wifes Car was Last month Build Of 2006 Line & my car was Built oct 2005! Same radios same everything but She Has a SS/na! You Can do what Im Doing & Just Tap the Hole in the antenna to Fit Yours!
On a Side Note LSJPUP aka Josh Tried it on his car it fit No Problem! Simply go to pep boys or what ever & tap it out Bigger is the easiest way!
Old Oct 28, 2006 | 08:28 PM
BlilBT's Avatar
See the Laser Blue Cobalt SS in the background >> Thats my Wifes it was made in June 06
See the Shorty I have On My car >>> IT WILL NOT FIT on Her Car!
Only thing I can Figure is >>She got the 07 Radio & Stuff Because of Build Date & GM on the 07's Has Changed the Size of the Thread Bolt on the Mount!
Old Oct 28, 2006 | 09:51 PM
tiny's Avatar
yep, the 07 has a different antenna base
not sure why
Old Oct 29, 2006 | 04:56 PM
NUYORKAH's Avatar
not sure why
2007 have a 7mm base.
Earlier years have a 6mm base.
Old Oct 30, 2006 | 12:54 AM
leviticus88's Avatar
Buy or "find" a Honda Element antenna and drill and tap it to fit either 6mm or 7mm for your year. Looks great and was cheap.
Old Oct 30, 2006 | 04:19 PM
topher21's Avatar
Leviticus I just found one on ebay and wound like to know how u modified it, i mean how did u get the threads to match the 7mm base on the 2007ss I really have no clue as how to modify it thanks for ur time!
Old Sep 9, 2013 | 01:54 PM
Kap_Kayaker's Avatar
Exterior - MPx Shorty Antenna 07+ Cobalt
This is the one I ordered for my Cobalt 2007
Old Sep 9, 2013 | 01:59 PM
blueLNFftw's Avatar
not quite.
There is a split in 2006.
Earlier made 2006 cars will have the 6.5mm shaft base. Later build ones will have the 7mm base. There is no definitive split known based on the date code so you MUST MEASURE YOUR SHAFT before you buy a new antenna if you have an 06. Depending on the size depends what to buy. All 2007+ use the 7mm base though, so do any replacement bases sold by GM.
Old Sep 9, 2013 | 02:16 PM
andrewcarr1993's Avatar
7 year thread bump FTW
Old Sep 9, 2013 | 04:28 PM
MrZim4's Avatar
Hah " MEASURE YOUR SHAFT"
RaginChopsuey
Oct 27, 2015 01:27 PM
agentirons
Oct 16, 2015 02:11 AM
Sep 28, 2015 12:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
