should i do this or that....
Good man! Be different!
but do this. TVS makes SC's happy.
TVS plz! ported head, 1mm over sized valves, built head (springs, retainers, etc) comp cams blower grind, ported intake mani, dual pass, hatricksu's coolant mod, ZZP heat exchanger, R.A.W. intake, ZZP or Vibrant header/DP, 2.5" exhaust, light weight crank pulley, neutral balance shafts...
the above is my dream build assuming im going blower only. Otherwise, I love the twincharge route.
guess im the queerest of them all then cause im leading they way in wisconsin
been there done that lol...
told ya man.... you need a tune and a nicely built motor. turbo is a simple way to get rid of a lot of the supercharged guys see and will provide you enough power to propel you into the 12s
you wont see 12's on the blower....and a bottle
you can but i feel you could do a better setup then stage 3 and a dry 50 shot on a built motor.
cams, valvetrain, ported head, 2.8 pulley, and a 75 wet shot would probably get him there with a good launch. weight is a factor so thats why i say probably...
btw wheres my spring compressors lol
haha says the guy with a 2.2
and thats the stock motot all torn down (and it the non blown up one Zspeed haha) and ready for the big build up.
here is some stuff i bought yesterday...
ARP head studs
Diamond pistions
Cometic head gasket
poly trans mounts
GMPP hardened oil pump
AI performance rod bolts
GM gasket and rebuild kit
GMP neutral balance shafts
Stiffer valve spring kit (from OTT)
front mount heat exchanger
stage 2 axles
272 cam regrind
ARP head studs
Diamond pistions
Cometic head gasket
poly trans mounts
stage 2 axles
272 cam regrind
in my trunk... tuna left them there.. ill catch up to you this weekend.
ARP head studs
Diamond pistions
Cometic head gasket
poly trans mounts
stage 2 axles
272 cam regrind
ARP head studs
Diamond pistions
Cometic head gasket
poly trans mounts
stage 2 axles
272 cam regrind
says the guy who thought yourcobalt was better then dot net
Last edited by nramlow2006; Sep 18, 2008 at 10:59 AM. Reason: Automerged Doublepost
ok ok you two stop the pissing match, i think from what i saw with the bottle on my car, that he will be in the 12s IF he goes with the bottle.
If you do it right, the bottle is a beautiful thing.
Last edited by 07cobaltguy; Sep 18, 2008 at 11:07 AM. Reason: Automerged Doublepost
Replace the M62 with the TVC though.
Sorry, miss this post before I started talking about the TVS. Let me know how that works out for you, I'm debating between the TVS or the Hahn turbo setup. I think you'll hit 300 or so w/o spray with the TVS though. My question is how hard will your launch be?
so to my record street attack has taken 4 motors out of commission
Replace the M62 with the TVS though.
tvs would for sure get him there.... area 47 has proven that already...
