ss supercharged gas question
Old Nov 22, 2004 | 12:50 PM
rxxxryan's Avatar
Will the ss supercharged require premium gas?
Old Nov 22, 2004 | 01:37 PM
turbostang's Avatar
To make max power yes, to run normally no.
Old Nov 22, 2004 | 01:41 PM
JonyyB's Avatar
Site Founder
agreed
Old Nov 22, 2004 | 01:49 PM
zstyle's Avatar
I'm sure I read that they recommend premium, but I'm sure it's the same as the Gen IV 3800 SC. Premium is recommended for best performance, but only regular is required, as the engine will detect the change and retard the timing.
Old Nov 22, 2004 | 02:05 PM
mrinella's Avatar
The manual recomends 91 octane for the SS.
Old Nov 22, 2004 | 02:48 PM
Eddie's Avatar
eh half 91 half 100 octain, i'll be good. lol
Old Nov 22, 2004 | 05:05 PM
zinner's Avatar
Moderator Alumni
If they require 91 in the manual you would be ill advised to use 87.
Even with a knock sensor there is still a detonation occuring before it can sense the knock and back down the timing.
Old Nov 22, 2004 | 05:40 PM
b-spot's Avatar
It is documented that 87 is acceptable, or atleast it was, on chevy's site. It did say that performance would decrease though (obviously)
Old Nov 23, 2004 | 12:20 PM
Vita's Avatar
performance will decrease as the computer will try and get things in control, if it says use 91+, use 91+, my redline only gets 93 and there is a reason that they tell you to use it. the car is DESIGNED to use it, using lower octane will reduce the life of the engine. if you're buying a sportscar, why cheap out on $2.00/tank?
Old Jan 26, 2005 | 12:42 AM
giovanhalen's Avatar
gasoline
Also retarding the timing will lower the gas mileage.
Old Jan 26, 2005 | 01:41 AM
p7x's Avatar
p7x
Well put Vita
Old Jan 26, 2005 | 07:46 AM
Archplsm's Avatar
Think about it ....... the engine has a 10:1 compression ratio. If you use less than 91+ you are asking the engine to make up for the reduced power provided by higher octane to break the compression inhearent in the engine. By doing this you are putting more stress on the componets of the engine at a lower octane......... What do you want to do? save money now or save money on engine repairs in the long run
Old Jan 26, 2005 | 10:02 AM
rxxxryan's Avatar
but if you just using it for daily driving do you think it will matter?
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
