SS v. LS: Whats the difference??
Old Oct 26, 2007 | 03:06 PM
thedub784's Avatar
I was wondering what the difference was between the SS balts and the LS balts other than the body kit and springs....
but what else is different on the SS compared to the LS??(exclude the 2.0/2.4L motor(supercharger) vs. the 2.2L)
Old Oct 26, 2007 | 03:09 PM
joeworkstoohard's Avatar
well...
the suspensions on all three are different. the hubs and brakes are different (for the most part)
the SS cars have better standard equipment, different dash trim, different exhausts.
the SS SC has even more, different transmission, different steering rack.
Old Oct 26, 2007 | 03:11 PM
Evil C's Avatar
mine came with heated leather seats and a sun roof 7 speaker sound oh and traction controll that can't be just turned off and driven normally
Old Oct 26, 2007 | 03:14 PM
thedub784's Avatar
suspension: basically springs....but not the SC version, just the SS....is the interior different?
Old Oct 26, 2007 | 03:17 PM
PenguinPIE's Avatar
much better brakes.... i experienced that when i got the SS
Old Oct 26, 2007 | 03:18 PM
different colors, yeah.
all SS cars are dark interior with silver trim
thedub784's Avatar
so ive got:
-suspension
-brakes(which are the same right?)
-SS body kit
-SS springs
-diff. exhaust
-interior color(black with silver)
anything else??
Old Oct 26, 2007 | 03:25 PM
OrngBalt's Avatar
Compared to your base the SS has:
Difference fascia (front and back), side skirts, fog lights, no exterior trim, different badges, lower ride height due to better springs, better shocks and struts, better sway bar, bigger rims, better tires, bigger brakes, 4 disc brakes, bigger engine, bigger throttle body, better exhaust manifold, better down pipe, better exhaust, darker interior, leather option, heated seats, different computer (tunable), better stereo system
that should be a good start
Old Oct 26, 2007 | 03:28 PM
thedub784's Avatar
your right, that is a GOOD start...thx for the help!
what shocks and struts are on the ss??
and the manifold can be put on an LS, right?
Old Oct 26, 2007 | 03:51 PM
OrngBalt's Avatar
shocks can be ordered right off CED... they dont sell the base model, only the SS versions. The manifold is a direct swap.
Old Oct 26, 2007 | 03:56 PM
xCobalt05x's Avatar
Originally Posted by joeworkstoohard
well...
thats not entirely true about the dash trim. my dash trim is identical in my LS to both of the SS's (excluding the SS badge) and it came factory. Also my insterment cluster is identical to that of the SS/NA (white gauge face w/ 140mph speedo) that came standerd on the 05 LS's w/ the sport package. Even the exhaust tip was that of the SS/NA with the LS sport package's
Old Oct 26, 2007 | 04:06 PM
Redtide's Avatar
supercharger!!!
Old Oct 26, 2007 | 04:11 PM
you sure about that?
the tips are different on the 06s
Old Oct 26, 2007 | 04:13 PM
thedub784's Avatar
Originally Posted by Redtide
supercharger!!!
plz read the first post, we already got it, thx tho...
xCobalt05x's Avatar
Like i said, I have an 05. the stock muffler was identical to the stock muffler of the 05 SS/NA including the tip. Was part of the sport package for the 05 LS's. some other things that came standard on the sport packaged LS was that i found out i had no govenor (found that out racing an eclipse on the interstate when i hit 125 and then hit the rev limiter and watched him pull away)
Old Oct 26, 2007 | 04:16 PM
just seems odd...
my friend's 05 LS sport package has the LT tip.
Old Oct 26, 2007 | 04:31 PM
Cobalt443's Avatar
There is no 05 2.4 SS
Old Oct 26, 2007 | 04:50 PM
thedub784's Avatar
if i get the ss mani do i have to get it tuned?
on a 2.2l don't forget?
Old Oct 26, 2007 | 04:54 PM
halfj99's Avatar
no..
Old Oct 26, 2007 | 04:55 PM
Black07SS's Avatar
just a quick question. i find it cool that you are trying to swap your to an SS....but wouldnt it be cheaper to just buy a used SS 2.4?
Old Oct 26, 2007 | 04:58 PM
alleycat58's Avatar
LOL you beat me to it Debbie!
And I have NEVER seen an SS tip "standard" on a lower model. I've seen the lower models with the high polished tip, but it's different from the SS/NA tip.
so ive got:
-suspension
-SS body kit
-SS springs
-diff. exhaust
anything else??
Brakes are WAY different.
LS = front disc, rear drum
SS = 4 wheel disc
They're NOT easily converted either for a plethora of reasons.
Last edited by alleycat58; Oct 26, 2007 at 04:59 PM. Reason: Automerged Doublepost
Old Oct 26, 2007 | 05:02 PM
SS = 4 wheel disc
using a mix of parts from a 07 LT and an 06/07 SS 2.4, it looks doable to swap the brakes.
but... why bother?
Old Oct 26, 2007 | 05:07 PM
SSbolt's Avatar
you get more ***** in an ss sc
Old Oct 26, 2007 | 05:10 PM
alleycat58's Avatar
but... why bother?
I understand what you're saying but I would think there would be a lot more roadblocks in swapping with a 2005 LS. I know there have been changes and upgrades, I'd just want to make real darn sure everything was copasetic with each other. Brakes are one area you don't want to "experiment" with.
Old Oct 26, 2007 | 05:15 PM
i'm not disagreeing... but we did look at the blown up view... and it would be doable...
but, for the cost, effort, and the risk factor... there isn't any real reason to.
even if you were road racing, it would be better to just beef up the brakes already there, and if you need even more, you probably need more car.
