Storing for Winter?
Crawl underneath it and look at the unibody and rear beam. I guarantee it there, unless you frequently wash and flush the underside of your car.
Everything I do has already been mentioned, inflate the tires to 36 PSI, battery tender, blocking off the intake inlet and exhaust tip
Snobalt is snow hero! I've driven mine ~365 for the last 4 years and 85,000mi, no reason to stop now. We only see a couple days of snow and they use antifreeze on the roads instead of salt.
For tire pressure you should never exceed the stamping on the side of the tire (usually 40-50psi). But I'd personally put it up on stands, isn't going to hurt the suspension having it all the way out for a few months.
Off topic: She's totally going to install those skinny ass tires on that 6 series
Originally Posted by tirerack.com
Don't store a vehicle with weight on its tires for extended periods of time. Long-term inactivity is more harmful to tires than weekly drives that flex the tires and help maintain oil dispersion within the rubber compounds.
Originally Posted by Michelinman.com
If tires are on vehicle, store on blocks to remove load from the tires. Maintain placard inflation pressure.
One October we had a freak snow storm that dropped 4" over night (didnt even know about it). Had to suck it up, and drive the car to work. Not one slide or slip from her.
Thankfully, I had all seasons at the time.
Yea man. I drove to a funeral last winter 45 min down the highway in a white out. People were driving 40km/h on the highway, i was doing 70-80km with ease... Than down what was a dirt road, snow was rolling over my hood it was so deep and it crawled through, backed up in the drive way and got moving agIn like a dream. By far the best handling car Ive ever driven in our canadian winters
i usually rust check my car before winter storage, fill up full of gas / stabilizer, remove my meth kit, and disconnect battery, thats it. goes in cold storage, once the doors are locked they dont open until may/june.
second year storing my car
fill the tank and put stabilizer in
wash the car, take the wheels off and wash them
i over inflate the tires to 40psi and park it on carpet, also i make sure there is carpet under the whole car (helps soak up any moisture)
plug the battery tender in ( i have the cord running out of my trunk so no need to take the battery out)
cover the car up with my car cover
(maybe start it once or twice during the winter)
then wait till may ish to get it back out!
i dont mind to drive it in the winter, i mean it IS a car and made to handle well all weather.. but to be honest i just dont like the ABS in the snow... seeing how i've never had a car with ABS its a new thing to me and in the snow yeah i dont like it hah
chances are it'll sit in a garage, no sta-bil, nothing special i'll just either go start it and let it warm up x times a week or i'll have the person who's garage it is do it... but i do hope its a mild snow winter that'd be best
I usually change oil within 3000km of parking
fill tank
disconnect battery
I start it every two weeks and do slow laps around the alley until its warmed up then let it idle for a few mins before parking it.
lul if you engage abs you would have slid into the person in front of you without it anyway. Its driving technique not the cars fault.
fill tank
disconnect battery
Sent from my Samsung Galaxy Note booyahh
Everyone hear is saying over inflate the tires to somewhere between 36-40 psi. I run my tires normally at 45 psi on my LNF. Should I over inflate them anymore if I am going to put the car in storage?
To answer your question then, no 45 psi is plenty to store it and not really have to worry about flat spots in the tires. I would still move the car a foot forward or backward once in a while just to be sure. That's what I do.
Check the inside of your door sill for the correct cold tire pressure.
Should be 32 psi.
