sunroof adjustments
Old Apr 30, 2008 | 12:32 PM
SSinPA's Avatar
sunroof adjustments
Is there anyway to adjust the sunroof so it closes tighter? Mine rattles like a bitch.
Old Apr 30, 2008 | 12:38 PM
SilvrLT's Avatar
my sunroof does the same thing, took it to the dealer and was told they couldent fix it
Old Apr 30, 2008 | 12:45 PM
tiny's Avatar
try putting some foam in there and see if it helps
Old Apr 30, 2008 | 06:31 PM
Evil C's Avatar
mine does not rattle yet when did it start ratlin?
Old May 4, 2008 | 11:37 AM
SSinPA's Avatar
it started after prolly a year
lol those ******* at the dearlership are gonna fix it for good i will insure that. I hate temporary fixes and i want real fixes. I'm sick of them dicking me around. they are gonna make it close tigher that is for sure.
Old May 4, 2008 | 11:55 AM
Stouffer's Avatar
There is TSB for the sunroof. Look in the problems/service section on here.
Old May 4, 2008 | 12:07 PM
Jackalope's Avatar
The sunroof is a problem spot for the Balt. I had mine changed out due to the same thing and saddly there are no adjustments tat can be made, it needs to be replaced. Its a complete unit and its pricey as ****! It should however be covered under warrenty so go back to the dealer.
Old May 4, 2008 | 12:10 PM
Stouffer's Avatar
Jack, there is minor adjustment that they can try first. After 3 trips for mine leaking I am hoping that they finally got it right. The seal does sit up a bit higher than before after the adjustment. Just waiting for enough rain to see.
BTW, way search speed channel for the show Test Drive with Tommy Kendall. They jsut did a silly test of the new M3
Jan 12, 2016 12:01 AM
chefhhr
Oct 26, 2015 10:36 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
