Supercharged 2.2s Chime In
Old Jan 26, 2012 | 11:38 PM
  #51
nhanson's Avatar
Originally Posted by Raiden8816
2006
Trifecta Tune
Automatic
Stock Pulley
Option B Dual Pass
Stock LSJ Heat Exchanger
80lb
Autolite 1-Step Colder plugs
RD Fabs 3" CAI
Been having idle issues for over a year only have 6 revisions to tune. Hopefully I can get it sorted out this year, getting tired of brake boosting everywhere.
I can see why. 80 lb injectors on a stock pulley? You could drop to 42s!
Old Jan 26, 2012 | 11:42 PM
  #52
drumrush's Avatar
yeah those are HUGE injectors lol
Old Jan 26, 2012 | 11:44 PM
  #53
zerosk8ter83's Avatar
I was gonna say the same... drop it to 42
Old Jan 26, 2012 | 11:45 PM
  #54
drumrush's Avatar
even im about to drop to 42's
Old Jan 26, 2012 | 11:50 PM
  #55
nhanson's Avatar
drop to 2.8 or 2.9
im gonna do 2.9 right away when it goes on
Old Jan 26, 2012 | 11:53 PM
  #56
dont drop a pulley unless you got the cooling mods for it.I have the 2.9 on and I have heat prombs
Old Jan 26, 2012 | 11:54 PM
  #57
nhanson's Avatar
i thought he had cooling mods (could be mistaking)
so far i bought ZZP S3 heat exchanger and dual pass plate.
i will also be installing option b right away
do stuff right ONCE
Old Jan 26, 2012 | 11:58 PM
  #58
drumrush's Avatar
come summer im taking off the cobra h/e and putting on a zzp s3, dual pass and option b. maybe even meth
Old Jan 27, 2012 | 12:00 AM
  #59
I have the stg3 zzp HE,dual pass and option b....
Old Jan 27, 2012 | 12:01 AM
  #60
drumrush's Avatar
how do you have heat problems then?
is your pump working?
Old Jan 27, 2012 | 12:04 AM
  #61
yup its working,its prom because I have stock dp and header and I got my stupid ls bumper that blocks the intake from getting fresh air =(
Old Jan 27, 2012 | 12:06 AM
  #62
drumrush's Avatar
full exhaust will help
Old Jan 27, 2012 | 12:08 AM
  #63
Tundraboarder666's Avatar
LSJ and L61 run a completely different plug... LSJ is tapered and doesn't fully reach into the chamber... it will def help to get the right plug in there. ask me how I know lol
Old Jan 27, 2012 | 12:09 AM
  #64
I have the catback on, just need to finish the rest
maybe I should put my stock plugs back on....
Last edited by zerosk8ter83; Jan 27, 2012 at 12:09 AM. Reason: Automerged Doublepost
Old Jan 27, 2012 | 12:10 AM
  #65
drumrush's Avatar
you need one step colder to prevent misfires
Old Jan 27, 2012 | 12:27 AM
  #66
1LowLS's Avatar
L61 needs to be taper seat and 25mm reach.
Im on a 2.9 with stock endplate,terminator flow through option b and massive ottp front mount.no iat probs here
Old Jan 27, 2012 | 12:49 AM
  #67
well I just took my ngk off and I compared it to the stock spark plug.....Im gonna go buy some new ones right now theres a huge difference the ngks are way shorter then the stock,any tips on which brand to get from autozone?
Old Jan 27, 2012 | 02:06 AM
  #68
NOT autolites... Just get some NGK's
Old Jan 27, 2012 | 02:36 AM
  #69
evofire's Avatar
ac delco or ngk's
i have stock ss/sc plumbing into a cobra heat exchanger and i have no heat problems....
Old Jan 27, 2012 | 02:45 AM
  #70
1LowLS's Avatar
People are dumb lol.I have 2 step colder Autolites and there fine.even went 1 step colder LNF plugs and were fine.Misfires are in the tune.yes NGK are great but my autolites work just as well and they are locally stocked.I read the problems people were having with Autolite as well and jumped on the band wagon until I swapped to lnf plugs and my stock delcos and the idle misfires were still there.Seriously.Autolites will work just fine as they work just fine in my SC 2.2
Old Jan 27, 2012 | 02:54 AM
  #71
heathkidder's Avatar
i think some of the issues is the map sensor or injectors
im hoping im a lucky one lol
Old Jan 27, 2012 | 03:12 AM
  #72
bought some NGK's it pulls alittle harder but still seems to be getting knock BUT it did eliminate the stalling from the run promblem
Old Jan 27, 2012 | 03:33 AM
  #73
how do you guys have your laminova cores setup?
Old Jan 27, 2012 | 03:43 AM
  #74
1LowLS's Avatar
stock lol.My endplate has never been off the manifold
Old Jan 27, 2012 | 07:05 AM
  #75
jbenso4's Avatar
Can I have a part number for the correct plugs to use? I use NGK LFR6A-11
