Supercharged 2.2s Chime In
Old Jan 26, 2012 | 10:27 AM
jbenso4's Avatar
m62, zzp 2.9" pulley, stock lsj cooling system, lsj TB, lsj header and 2.5" catback. I need to get a bigger DP and a bigger h/e. I was tuned by trifecta, and The issue im having comes up as a TB sensor code. Ill check later for the actual codes on my scan tool. For instance if Im full throttle, the car goes into limp mode randomly. It doesnt happen everytime, but im getting sick of it. I have to pull over, and turn the car off for like 30 seconds.
Old Jan 26, 2012 | 11:10 AM
1LowLS's Avatar
Did you wire in the LSJ TB?
Old Jan 26, 2012 | 11:16 AM
GSDIESEL300's Avatar
Lsj intake mani, m62, 2.9 pulley, stage 3 zzp heat exchanger, dual pass, 60# injectors, injen intake, trifecta tune. No idle issues or misfires. 15-16 psi runs strong put a couple thousand miles on it and no problems.
Old Jan 26, 2012 | 11:17 AM
jbenso4's Avatar
yes i did. crimp and solder
Old Jan 26, 2012 | 11:26 AM
Axelthered05's Avatar
what map are you using?
Old Jan 26, 2012 | 11:39 AM
jbenso4's Avatar
i use stock map forgot to add that
Old Jan 26, 2012 | 11:44 AM
Stock 2.2 map
Chevycobaltss3's Avatar
Lol I tuned a hhr 2.2 built and a auto. With a tvs and Meth 2.6 pulley blown the trans. And now is fully built on everthing... Issue is Cams. Not to big. So idle had to be raised up for a better dd idle.
Old Jan 26, 2012 | 11:50 AM
jbenso4's Avatar
I can use HP Tuners with my car, i wish u werent so far away id have you do my car. I dont want a mail tune again
Old Jan 26, 2012 | 11:55 AM
drumrush's Avatar
Over the summer I might drive down to see you, its only like 6 hours haha
Old Jan 26, 2012 | 04:13 PM
  #36
zerosk8ter83's Avatar
I cant use hpt im 06 =(
Old Jan 26, 2012 | 04:39 PM
  #37
Same here FML
Old Jan 26, 2012 | 04:53 PM
  #38
evofire's Avatar
2004 sunfire m62 3.0 pulley cobra heat exchanger....oh wait....nevermind....i have a pretty good GM tune and no issues!
Old Jan 26, 2012 | 06:15 PM
  #39
what did you guys gap your spark plugs to?
Old Jan 26, 2012 | 06:26 PM
  #40
evofire's Avatar
im still on stock plugs at stcok gap
  #41
jbenso4's Avatar
I'm running the lsj plugs too. What ones should I be using
Old Jan 26, 2012 | 06:35 PM
  #42
evofire's Avatar
arent the lsj plugs and the l61/LAP plugs different?
Old Jan 26, 2012 | 06:37 PM
  #43
Yes.. shouldn't be using lsj plugs ....
Old Jan 26, 2012 | 06:44 PM
  #44
nhanson's Avatar
Buy L61 plugs but 1 step colder...or maybe 2
Old Jan 26, 2012 | 08:09 PM
  #45
Im running the ngk plugs 1 step colder from zzp so....ss or not they fit on my car lol
Old Jan 26, 2012 | 08:16 PM
  #46
Raiden8816's Avatar
2006
Trifecta Tune
Automatic
Stock Pulley
Option B Dual Pass
Stock LSJ Heat Exchanger
80lb
Autolite 1-Step Colder plugs
RD Fabs 3" CAI
Been having idle issues for over a year only have 6 revisions to tune. Hopefully I can get it sorted out this year, getting tired of brake boosting everywhere.
Old Jan 26, 2012 | 08:17 PM
  #47
I have the ngk 1 step colder, not lsj. I really don't know how or why anyone is having problems because I got my tune dialed in after the first few updates.
  #48
Coby The Killer's Avatar
Im running a ZZP kit and chose to go with stage 2. To this day i have had no problems besides running a little to rich
Old Jan 26, 2012 | 08:19 PM
  #49
and i am trifecta tuned as well
Old Jan 26, 2012 | 09:48 PM
  #50
IonNinja's Avatar
3" pulley, 60s, cobra HE, 3" intake, LSJ exhaust manifold, 2.5" ZZP catless downpipe, 2.5" exhaust, patriot stage 2 ported head, trifecta tuned
had the following problems:
1) injectors not sealing in head
-fixed with new o-rings
2) LSJ throttle body not wired correctly
-found out TB wiring is different between Cobalt/Ion, got Ion schematic from Vince
3) turbulence around MAF causing skewed readings
-made sure MAF was located in straight piping with no nearby bends
4) spark blowout
-tightened plug gap down to .030
5) intercooler pump not working
-replaced intercooler pump
6) primary o2 sensor supposedly not reading correctly
-had problems getting my tune dialed in completely, Vince claimed my o2 sensor was off because it was reading leaner than it really was. never really resolved this but car runs okay for now
7) car misfiring
-42s were poorly spliced into factory harness. switched to EV6 injectors and a new stock injector harness (plug & play)
I've been through it all
