Supercharger reinstall help
Old Aug 9, 2014 | 05:19 PM
G5_Stuntin's Avatar
Removed the supercharger to be painted and now was wondering if any can help me with some tips on how to put the supercharger back on. Thanks!
Old Aug 10, 2014 | 12:27 AM
Gmoney06's Avatar
Goes back on in the reverse order of taking it off. Just be careful of the gasket and bolt it back on.
Old Aug 10, 2014 | 10:11 AM
TStone's Avatar
Bolt it on with the 4 bolts that hold it on. Bolt throttle body to blower. Hook up air intake. Plug in throttle body connector. Plug in scip sensor on top of blwoer. Plug on your brake booster hose. Hook on evap line on throttle body. Put belt on. Hook up vac lines for bypass valve & boost solenoid
Old Aug 10, 2014 | 02:13 PM
G5_Stuntin's Avatar
Is it easier to put the belt on first and then bolt it down or bolt it down first and then put the belt on
Old Aug 10, 2014 | 02:24 PM
TStone's Avatar
Old Aug 10, 2014 | 03:35 PM
G5_Stuntin's Avatar
Thanks for the help everyone! Got it back on and everything seems to be running fine. I'll give an update once I drive it a little bit more. Again I appreciate the help I'm a serious noob when it comes to this kind of stuff. I'm gonna try and get the valve cover off and painted next how easy is that to do?
Old Aug 10, 2014 | 04:08 PM
TStone's Avatar
Easier than the supercharger. Just some bolts
Old Aug 10, 2014 | 06:12 PM
G5_Stuntin's Avatar
I read that you have to take off the fuel line is that true?
Old Aug 10, 2014 | 06:16 PM
TStone's Avatar
don't have to. but take the 2 bolts out that hold it to te head.......... that way you can pry it back out of the way to get to a couple of the front valve cover bolts
Old Aug 10, 2014 | 09:45 PM
G5_Stuntin's Avatar
Okay awesome. Thanks for the help TStone I really appreciate it. Sorry for all the noob questions
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
NoBalt123
Sep 4, 2015 07:10 AM
