Is there any way to check the accuracy of our temp guage?
Old Feb 21, 2006 | 06:18 AM
Steeltown Pursuit's Avatar
I'm curious to know if anyone knows how to check the accuracy of the temp read outs on the DIC.
I'm curious about the engine temp accuracy as well as the external temp accuracy.
I've always found specifically with the external temp that it's always 2-3 C above what I hear on the news. ie reading will say 3C when I hear the news say it will be around 0C.
any thoughts?
Old Feb 21, 2006 | 07:32 AM
3fo893013L's Avatar
Look at a bank with a temp gauge. Those are pretty far off (about 5 degrees farenheit) typically. It's because there sensor is in the shade.
The Cobalt DIC Outside temp reading is within I found about 1-2 degrees off.
The Cobalt DIC Engine temp is literally within 1 degree off from the real reading.
Old Feb 21, 2006 | 11:41 AM
So now that we know the outside temp is off, is there any way to correct it and make it more accurate?
can we relocate the sensor or change the computer to make it 1-2 degrees cooler? I find my outside time is 1-3 degrees C hot....
does anyone know where the outside temp sensor is? maybe the engine bay heat is affecting the reading?
any ideas?
Old Feb 21, 2006 | 11:43 AM
3fo893013L's Avatar
any ideas?
I believe the sensor is not fitted to anywhere by the engine bay but I could be wrong. I would be bad to put it in a place that generates such heat.
Old Feb 21, 2006 | 12:40 PM
silverSS's Avatar
why mess with it, just leave it alone, who cares, its not a big deal, to me at least?
Old Feb 21, 2006 | 12:52 PM
c7015's Avatar
Becasue knowing the temperature, acurate to a degree is essential to carry out daily functions?
Old Feb 21, 2006 | 01:04 PM
wes_woodbridge_ss's Avatar
Buy a f****n thermometre and hang it from ur wing if ur that paranoid about a one to three degree range. Are u feeling ok?
Old Feb 21, 2006 | 01:53 PM
freakaccident's Avatar
Um what daily functions do you do that you need to know the outside temp more accurately than +/-1-2*? A better question is if your job relys on that so much why on earth would you trust the DIC in your car? If you are some kind of engineer that must know temps outside to the degree I would think you would be smart enough to buy and accurate thermometer calibrated to the accuracy that your position requires.
Old Feb 21, 2006 | 01:59 PM
Cobalt443's Avatar
I have a digital outdoor temp. gauge at my house which is always right on with both, the local news and what the cobalt's gauge is reading
c7015's Avatar
when I am being ultra sarcastic I need to know the exact temp, so I don't spoil the obviousness of my post
Old Feb 21, 2006 | 03:13 PM
I suppose I should have noticed that.
Old Feb 21, 2006 | 03:18 PM
3fo893013L's Avatar
haha
ineedacobaltss
Nov 7, 2015 02:25 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
yellow dragon
Sep 28, 2015 09:49 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
